Padovani Labor-e 275 lathe retrofit
6 years 1 month ago #181743 by Masiwood123
Thank you friend,
i still didnt put mesa card i am waiting to arrive. but i just try with jumping wires to simodrive +24v. axis x and z are running well with battery but spindle i cannot start. At first time as you explain you try the same, did you try to start spindle with battery? i first enable simodrive power module(now is orange light) at your as i can see is green.Now on spindle driver says run, but when i try to run with battery 1.5v it is error f11(as i read this is over current something break spindle to start, maybe and installacion power motor needs 32A current). Cen you pleas send me photo of simodrive that i can see detailed terminal inputs 24v?
Thank you
6 years 1 month ago - 6 years 1 month ago #181876 by radom
yes I was able to start spindle with 1,2v battery
green light is missing enable, yellow/orange light is module ready so you're good
In my lathe power from simodrive to spindle goes through big motor contactor K1,
do you also have this contactor next to simodrive? does it work?
fault F-11 as I understand is basically drive doesnt sense that the motor is turning,
motor is stuck, faulty encoder, faulty wiring or faulty drive
Last edit: 6 years 1 month ago by radom.
6 years 1 month ago #181878 by Masiwood123
yes friend, mu lathe has doing well until i lost parametres so sinumerik with battery disharged and i didnt replace it properly.. now please see the photo in attach i see there is that contactor K1, How i can find him on motor?
ps i jumped all 24v wires input on 663, 65, e4, 48...on display that says RUN but not clear digits(blinking).. when i put battery on 56 and 14 than is error f11. i hope that encoder is ok and everuthing else but that contactor i dont knor does he enabe via rele?
Please send a photo of your spindle drive to se wires input 24v.
Thank you very much
6 years 1 month ago - 6 years 1 month ago #181888 by radom
you need to close K1 contactor before putting battery on 56&14, for testing you can even push it in with a screwdriver and hold it
I don't have an electrical diagram and don't remember at the moment which relay is responsible for K1
6 years 1 month ago #181893 by Masiwood123
thank you i find k1 before reply i also try this, but when i push that lightning and smells on k1:( .. i checked contactor after and it is ok, maybe some induction during contact or it back dc voltage to relay, maybe i can try to unplag wires from contactor which is going to relay and try again to use contactor as switch.can you tell me what says on your drive display?Run?
6 years 1 month ago #181923 by Masiwood123
I just started spindle, that was contactor as you said. Thank you very much i am waiting mesa 7i77 maybe needs some other help.. I am happy like a child, thank you all the best
Time to create page: 0.150 seconds
