Padovani Labor-e 275 lathe retrofit
7 years 3 months ago #140845 by andypugh
That's a bit of monster!
Is that a D1-nose on the outboard end of the spindle?
7 years 3 months ago - 7 years 3 months ago #140896 by radom
yes, D1-8 on both ends, 108mm spindle bore
Last edit: 7 years 3 months ago by radom.
6 years 11 months ago - 6 years 11 months ago #150958 by Japantuning
Hello Mr Radom :) I have a simular Padavoni cnc (Labor E200). I cannot get hold of the original ore simular parameter files for the Sinumerik 805 controller.
So i have 2 questions here:
Do you have backup of parameters from your machine? if so, any chance we can buy them from you?
I could use them and adapt them to our machine.
Option nr 2: Retrofit this machine with Linuxcnc. if so, is there any chanse you can provide me with setup files/parameters used here?
Best Regards,
Ronny
Last edit: 6 years 11 months ago by Japantuning.
6 years 1 month ago #181166 by Masiwood123
Hi gays i also have labor e255 padovani, i would like if you can explain how to wire simodrive 611 to mesa 7i77? what wire is going from output to driver. thank you in advance
6 years 1 month ago #181167 by andypugh
The Simodrives are modular, do you know which modules you have?
I found this document which might be helpful:
cache.industry.siemens.com/dl/files/510/...2_A1014_englisch.pdf
or
cache.industry.siemens.com/dl/files/823/...2/v1/PJU_0613_en.pdf
The filenames suggest that they might be available in other languages too.
6 years 1 month ago #181244 by radom
example X axis - simodrive X331 pin 14 & 56 - mesa TB5 pin GND & AOUT0
X331 pin 65 - mesa TB5 ENA0-
X331 pin 9 - mesa TB5 ENA0+
same for Z axis X332
and similar for spindle X421 - pin 14 & 56 is +/-10V signal TB5 GND & AOUT
spindle enable X431 pin 9 - mesa TB5 ENA+, X431 pin 65 - ENA-
you also need to connect pin 663 pulse enable to pin 9, through mesa or safety circuit within your machine (e-stop etc)
it depends if you want spindle to brake or to coast down in a no-current condition when you hit e-stop
The following user(s) said Thank You: Masiwood123
