Encoders
- natholego11
- Thank you received: 4
For a s simple step/dir system with linear encoders and mesa hardware, I would use
a 7I96 +7I85 or 7I85S
so the 7i96 is Ethernet, but I dont see a way to interface the 7i85s to that card. forgive me for my ignorance, but how do you physically hood the system up?
- natholego11
So one step pulse is 6um or 0.00025". So that seems unlikely to be the problem. (Assuming no intermediate gearing)
Andy,
the problem that you are referencing is the inaccuracy in the machine? just to make sure I understand. and yes they are direct drive with lovejoy connectors.
- Clive S
- Thank you received: 486
The 7i76 is not ethernet so requires a 5i25 or 6i25 But the 7i76e is ethernet.
To connect the 7i85s to the 7i76 or 7i76e is done with cable from one of the ports of the 7i76 etc
photos.app.goo.gl/4uk7hE6X1a8MGhxH7
My bad I read the 7i96 as 7i76 sorry
- Thank you received: 5335
- natholego11
You connect the 7I85 or 7I85S to the 7I96's parallel expansion connector
ok so lets say I invest in this and move forward with purchasing all this stuff. my next question is nailing down a wiring diagram of these boards, as the manual that is on Mesa's site isnt the most inuitive. where could I get a good example?
and the next question is once I have everything hooked up, including the encoders, how do I tune the system so it doesnt go all psychopath on me while its trying to stay in the commanded position. ive seen some videos of people using the PID system and the scope that linux comes with, but it all seems foreign to me. any thoughts on that?
- natholego11
or use a fancier board like the 7I76E that has a buillt-in analog spindle
interface
You can also try setting all this up with your parallel ports. This will limit your
maximum speed, but the tuning and scaling issues are basically the same
regardless of what hardware interface you use.
- natholego11
- natholego11
