Encoders
  • Moderator
  • Moderator
31 Jul 2020 16:16 #176677 by tommylight
Replied by tommylight on topic Encoders
Nice. :)
  • natholego11
  • natholego11's Avatar Topic Author
  • Senior Member
  • Senior Member
18 Aug 2020 13:35 #178599 by natholego11
Replied by natholego11 on topic Encoders
Actually I wasn't assuming anything. By putting in your exact pitch calculation you are assuming that the pitch is accurate. I'm entering a calculation based on measurements because I know it is not. I don't care to fuss around with mapping ballscrews as my average is good enough for the tolerance of the machine I built. If you do wan't to map the ballscrews, wouldn't you want to measure your average real step ratio calculation with a physical device rather than assume it were closest to 4064 before you started?
Blazini,
Here is a link to THK's PDF referencing what I was referring to in terms of the accuracy of a ballscrew, they compare the commanded position vs the actual position. you can see the error that compounds on a typical screw.
pg 15-13
tech.thk.com/en/products/pdf/en_a15_011.pdf
