Encoders
  • natholego11
  • natholego11's Avatar Topic Author
  • Senior Member
  • Senior Member
18 Jun 2020 00:48 #171944 by natholego11
Replied by natholego11 on topic Encoders
ok, so i have installed and flashed my card. but I cant seem to get the 7i96 config to install, I cant even get past the first step of the python3-pip etc install. its telling me it cant find the files. any thoughts?
18 Jun 2020 00:57 #171945 by PCW
Replied by PCW on topic Encoders
I would use pncconf instead
  • natholego11
  • Senior Member
  • Senior Member
18 Jun 2020 00:58 #171946 by natholego11
I dont see the 7i96 as an option in there...
18 Jun 2020 01:05 #171948 by PCW
what version of LinuxCNC do you have?
  • natholego11
  • Senior Member
  • Senior Member
18 Jun 2020 01:08 #171949 by natholego11
im seeing debian 3.4.55-4Linuxcnc i686
18 Jun 2020 01:20 - 18 Jun 2020 01:21 #171951 by PCW
That's the kernel info
The LinuxCNC version is on the top bar of the LinuxCNC GUI so if you
launch LinuxCNC (a sim config so you don't require hardware setup)
you should see the version
Last edit: 18 Jun 2020 01:21 by PCW.
  • natholego11
  • Senior Member
  • Senior Member
18 Jun 2020 01:28 - 18 Jun 2020 01:30 #171952 by natholego11
this is what I am seeing at the login screen. im not sure why its upside down when it uploads on here...
Last edit: 18 Jun 2020 01:30 by natholego11.
18 Jun 2020 01:33 #171954 by PCW
Unfortunately, thats the wrong Linux kernl version for the 7I96, you need the uspace version of LinucCNC and a Preempt-RT kernel:
www.linuxcnc.org/testing-stretch-rtpreempt/
  • natholego11
  • Senior Member
  • Senior Member
18 Jun 2020 01:37 #171956 by natholego11
ok, so the Debian 9 stretch on the linuxcnc download page is appropriate? im not sure what I am looking at in that url you sent.
18 Jun 2020 02:06 #171961 by PCW
Yes though you would need to then upgrade to LinuxCNC
2.8 or master to get the 7I96 support in pncconf
Time to create page: 0.260 seconds
