7i96 Spindle Wiring
- Thank you received: 7496
25 Feb 2020 13:56 #158455
Replied by tommylight on topic 7i96 Spindle Wiring
How many wires go to the spindle ?Dang that is old, there is an Intel 386EX processor in it ! That was 1991 or 2 !
The easiest way, ditch everything, get 3 drives, even the cheap 10 $ ones will do, just avoid TB6560 something something. TB6600 will do, although 90% of claimed TB6600 on the net are not TB6600, they are TB something 109, and they are good, they can do 3 to 3.5A, so plenty for your machine. The spindle controll through an "arduino" relay for 2 to 4$ and that would be it.
Oh, and a PC with parallel port.
- dzawacki
- Thank you received: 6
25 Feb 2020 14:17 - 25 Feb 2020 14:18 #158456
by dzawacki
Replied by dzawacki on topic 7i96 Spindle Wiring
Tommy, you're not far off the mark with the 1991 or 1992, I saw that on the circuit boards in a couple places.
To back up, what you are suggesting is basically what I have done. I kept the mechanics of the machine but upgraded the electrical. I have:
a 32-44V power supply
3 DM542 stepper drivers
and the Mesa 7i96 (so I can connect to it using ethernet because I really wanted to avoid getting a parallel port setup).
The spindle motor has 8 wires coming out of it.
Can you point me in a direction to understand better what you mean by an arduino relay to control the spindle? I like the sound of $2-4 to solve this issue.
Last edit: 25 Feb 2020 14:18 by dzawacki.
25 Feb 2020 14:21 - 25 Feb 2020 14:23 #158458
8 wires ?
That is strange, or not.
Hold on a bit, that relay might not work, we have to figure out what those wires do first.
More pictures, of the motor, motor wires coming out of the motor and motor wires connected to the control board.
I did notice something on the picture of the spindle control that pointed me to the spindle not being a simple DC motor.
Edit,
hmmm..... i quoted myself ... !
Need some rest, brain took a leave of absence !
Edit,
Last edit: 25 Feb 2020 14:23 by tommylight. Reason: reason above.
- dzawacki
25 Feb 2020 15:58 #158468
by dzawacki
Tommy, it looks like the last page of this datasheet contains the wiring information:
www.alltronics.com//mas_assets/acrobat/DIH23_30_013Z.pdf
Granted, this PDF was created nearly 20 years after that motor was first installed, so there's a chance something might have changed with the specifications in that time.
25 Feb 2020 17:39 #158474
That confirms my suspicions of it being a 3 phase motor, i saw 3 heat sink transistors on the board with their pins going straight to the motor connector.
That complicates things a bit, but not much as the 3 phase drives for that size are cheap enough.....
Oh hell, i just checked again, it draws over 50A nominal !
Back to square one, you need an RC brush-less motor drive, preferably sensored as the motor has sensors built in.
Subsequently, that requires a different type of control, namely pulse duration modulation, usually from 1 to 2ms, and i recall a user here did make a similar setup work to the point of being useful.
I also know there is an option of choosing PDM in stepconfig regarding spindle control but i never used it so i am not sure it is about the same thing.
Do some digging, see what you can find.
- dzawacki
25 Feb 2020 18:48 #158480
by dzawacki
Tommy, if I am understanding correctly, I can use the motor that I have provided I can find an appropriately sized BLDC motor drive (something similar to
www.amazon.com/koulate-Stepper-Controlle...5-220/dp/B07T4GCC8H/
I assume the limiting factor here is finding a controller that can handle 50A? A quick search of Amazon is showing me only 15A options.
25 Feb 2020 20:17 #158486
That will work, but very low power.
RC ESC , for remote controled cars and planes and drones. They go up to 220A at 20 ish volts.
Your motor needs 50A at 6.something volts, so any of those RC ones will do, even the 2S ones.
- dzawacki
25 Feb 2020 20:24 #158488
by dzawacki
Oh, got it. I assumed the RC was a typo (especially given its proximity to the 'd' on the keyboard).
I'll look into some options. Thanks!
- dzawacki
25 Feb 2020 21:22 #158493
by dzawacki
A bit of searching on Amazon yielded this:
www.amazon.com/Xiangtat-Hobbywing-10BL12...hless/dp/B082SVKFS1/
It seems to meet the specifications that Tommy laid out.
Assuming this works, I guess my next question is what do I do with it? And what does it do? Is it wired between the motor and the 7i96 and the software and dictate when to turn the spindle motor on and off? Or is it wired independent of the Mesa card requiring me to manually turn it on and off? Either one is fine with me, I just want to know what I'm getting myself into.
I'll likely need some hand-holding, as most electrical work and motor control is usually outside of my wheelhouse.
25 Feb 2020 21:54 - 25 Feb 2020 21:55 #158494
Yup that is it.
It is nice as it has manual controls so you can use it as is manually.
It can be controlled from Linuxcnc but Linuxcnc outputs PWM or pulse width modulation, while that ESC uses pulse duration modulation, not the same thing, close, but not the same.
That would also require a big transformer !!!
Last edit: 25 Feb 2020 21:55 by tommylight. Reason: added more info
The following user(s) said Thank You: dzawacki
Time to create page: 0.114 seconds
