Bridgeport Torq-Cut TC4G Retrofit
5 years 6 months ago #205467 by chopper79
Just a simple video update of the current state on the retrofit.
The following user(s) said Thank You: tommylight, J Green
5 years 6 months ago #205470 by J Green
Looking good
So what is "The next stage " ?
Bob
The following user(s) said Thank You: chopper79
5 years 6 months ago #205476 by chopper79
Next stage will be:
* Finish all final connections that do not involve enclosure
* Install new X axis thrust bearings
* Verify geometry due to disassembly (Z axis finished, need to do X and Y)
* Refurbish way covers
* Install way covers
After that
* Jog pendent
* Control panel and touch screen
Then enclosure, enclosure light, and final tuning of everything. Will work on a new GUI after I am throwing chips all over the enclosure.
Got awhile to go due to lack of time available right now.
5 years 6 months ago #205480 by J Green
Align tool changer (Purchasing tools to align this) What tools did you use ?
Don't forget to share your latest INI and HAL files . They really helps others trying to do retrofits .
Bob
5 years 6 months ago - 5 years 6 months ago #205482 by chopper79
I was able to use the one from work to align the umbrella. Saved me $1200+
The tool has the 40 taper flange, adapter (goes in your tool pocket on umbrella) and then the centering pin. Keep adjusting umbrella assembly until everything is aligned. Snug bolts and recheck, then final tighten. I checked pockets ~90° from the next one so I had 4 points aligned with no issue.
Looks something like this.
Last edit: 5 years 6 months ago by chopper79.
5 years 6 months ago #205487 by J Green
Could you share your latest INI and HAL files . They really helps others trying to do retrofits .
Bob
