Bridgeport Torq-Cut TC4G Retrofit
5 years 2 months ago #216876 by chopper79
Hello all,
Just wanted to drop in and say that the mill project is still alive. Been very busy with a couple construction projects, work, farm stuff, etc and have had no extra time to work on the mill. Good thing is time is freeing up and I will be working on this again in the next couple weeks. Hope to have some good updates then.
Anyway until then hope everyone is doing well
5 years 2 months ago - 5 years 2 months ago #217569 by Michael
Just going through my spindle setup today and was wondering what you did with pin 41 coming out of the drive. It is labeled as TLIM for torque limiting and my drive was set at 50% with the stock DX-32 control.
When and where do you have this going into the control and for what use? Curious since its alternate use is for incremental control for orientation.
Last edit: 5 years 2 months ago by Michael.
5 years 2 months ago #217813 by chopper79
I am using torque limit (#41 pin) for gear change as that is what it was wired for originally. Hate to change gears in full torque. I can hear the gears crying with just the thought of it.
5 years 2 months ago - 5 years 2 months ago #218433 by Michael
Ignore this. I answered my own dumb question shortly after I posted. EMG needs 2.5 seconds before FWD can be enabled. The easy solution is to take the wire that is EMG/RDY/SSC to a 24v ground so that it closes with machine start. FWD goes to enable for spindle control.
I'm having issues running my spindle off speed reference (+/-10v). I can get it to spin just fine in digital operator mode. And it is enabling and receiving analog voltage from the 7i77. Kind of at a loss right now. I played with a bunch of settings in the drive but can't get it to move even a bit once out of digital operator mode.
I have the following setup for enable:
FWD pin 37, EMG pin 35, RDY pin 36, SSC pin 40 all going to ENA+ and ENA- going to 24v ground
COM pin 34 is the +24v
All the display signals in V1-09 show the above lines as being closed. FWD is its own wire coming out of the MR50 connector and EMG, RDY and SSC were all wired together from the factory. Is there some sort of timing or separate control needed for the RDY in the drive?
5 years 1 month ago - 5 years 1 month ago #220387 by chopper79
Glad you got it figured out.
I am on hold until Tuesday or Wednesday of this week. Currently waiting on my new granite angle so I can aligned the axis to each other since I disassembled everything. I did get the new X axis thrust bearings installed and those oil lines hooked up.
I was messing around with the acceleration values on the mill and noticed that I have the odd acceleration hesitation. Almost like the acceleration is delayed a bit for some reason. I will have to look into that more later on I guess.
Once I get the angle plate in then I will get everything aligned and can begin putting way covers on and other misc panels. Getting a bit closer to being done thankfully.
Last edit: 5 years 1 month ago by chopper79.
5 years 1 month ago - 5 years 1 month ago #220535 by chopper79
Ok just finished up squaring in the X,Y, and Z using a 0.0001" indicator and my granite angle
  • X -> Y = 0.0001"
  • Z -> X = 0.0002"
  • Z -> Y = 0.0001"
    Checked backlash also: (No backlash comp set)
    • X = 0.00015" (In between 0.0001" and 0.0002")
    • Y = 0.0001"
    • Z = 0.0001"
      With servo engaged I pushed (more like pry) the axis to see what the mechanical play was and if it returned to zero
      • X = 0.00025" and returns to zero each direction
      • Y = 0.0003" and returns to zero each direction
        Not to bad I have to say given the age of the machine. All bolts are torqued to proper spec. Time to begin the way covers.
Time to create page: 0.390 seconds
