Pressbrake CNC Control Setup Questions
5 years 2 months ago - 5 years 2 months ago #218023 by andypugh
It sort-of works for me, with the system going in to the "Overload" state of the pressure limit is exceeded.
You need something like:
net limit pressgui.max_pressure-f press.max-pressure net actual pressgui.pressure-gauge press.pressure
in the HAL.
But, also, the logic was a bit wrong. I think that this version is better, but once you have overloaded the system will only retract, it won't let you try again at the same position (unless you select the same bend again in the GUI, at least)
Last edit: 5 years 2 months ago by andypugh.
5 years 2 months ago #218075 by EW_CNC
Overload works! image missing /media/kunena/emoticons/smile.png
5 years 2 months ago #218076 by andypugh
Great.
I am still aware that homing needs further thought.
4 years 10 months ago #228476 by EW_CNC
Here is an update on my CNC Pressbrake control.
The ram control is working good, I'm using it regularly for bending.
I'll attach my latest files. My pressbrake is set up for imperial units.
The backstop can be jogged, but the homing for the backstop still needs work.
This is a stand-alone setup made possible with the efforts of Andy Pugh's press.comp.
Thanks All!
Screenshot:
File Name: Bender120621.tar.gz
File Size:30.36 KB
4 years 9 months ago #230805 by andypugh
Is the backstop homing the same whether it starts on the home switch or off the home switch?
Is there any chance that you can get a Halscope recording of the backstop motion? (I realise that this might be tricky)
4 years 9 months ago #230816 by EW_CNC
It's been awhile since I tried homing the backstop.
I'll see if I have time tomorrow to get some halscope readings and some more info on the backstop's motion while homing.
Time to create page: 0.087 seconds
