(OK...) I have been trying to read some more, therefore rather Edit my post... I am now planning to set my configuration up to be the same as yours.
First now, I am going to run a simulation on my laptop, to play around with it a bit, then learn what to do to best modify my configuration on the machine.
Thanks for the people who is involved here. I will provide feedback soon...
(here with my previous questions, and explanation of my machine's current configuration... (this is my first press brake, so I'm learning as I'm going here)
I'm interested in this. Does anyone have a simulation configuration on this yet? I started with a press brake about a year ago. It's a Amada APX300. It has 6-axis back-stops, and 3 Hydraulic cylinders with proportional hydraulic valves.
I have the back-stops left hand side as X,Y,Z, X-right = positive, Y-away from the ram = positive, and Z-Up= positive.
I have the back-stops right- hand side as U,V,W, U-right = positive, V-away from the ram = positive, and W-Up= positive.
My initial plan was to simplify it by making the Y and V joints, a Tandem Y-Axis. And at a later stage, when I have more knowledge of sheet metal bending, then I can separate the joints again, in order to bend cones / tapers.
So for now, I have the Ram as a A-axis, and then the dies come closer / closing the ram, then the A-axis move in negative direction, and when it opens, then it moves in positive direction. I know ideally A,B and C-axis should be rotating on a machine, but I made my Ram a linear A-axis. If there's specific rules that you should stick to in bending, for cam processing, I would like to know those rules, but these rules is just my own ideas, and I have just about no knowledge on sheet metal work. I only know Lathes and milling machines really. (turning centers, and machining centers.)
So I am very interested in this project, as it is something that I started, but put on hold, as I didn't know a lot of information. And now my mind is in a place again, where I want to learn more.
Please share if anyone has simulation configurations, or videos, or any information really, I would appreciate it.
Question: Is there a rule/ logic reason why linuxcnc is not ideal for a press brake? And is that something in development? I'm not much of a developer, and don't know much about programming, but is that something that the linuxcnc developers will include as a standard configuration within linuxcnc in the future? I know currently there's machining centers(like mills and routers) and there's turning centers(like lathes) and cutters (like plasmac/ plasma cutters, lasers, and waterjets) which works well. But many people currently is telling me that linuxcnc should not be used for press brakes. But I do think for developers to add in bending machines as a standard feature within linuxcnc, would be great. Because at this stage I think what I started, is not great, and people who saw my machine so far, thinks it's not great, and I should have rather spent money on a Delem control or something?
So configurations that would be great to add to linuxcnc (I think) would be : Bending machines and robotic arms (with rotating joints & standard kinematics, where the machine builder only need to fill in parameters, for joint-joint lengths, and options for 3,4,5,6 or 7 Axes robotic arms), with sample configurations? I know this is a lot of work, but I wish I had the knowledge how to get involved... and had the time... But maybe someone is already busy with this? We've built some robotic arms, and Prof. Rudy helped us with the kinematics, and 5-axis machining centers, etc., but I was like re-inventing the wheel almost... and I would not be able to do it without Prof. Rudy du Preez' help... My mind/Brain has a cut-off switch... when it hears math's / Algebra / Complicated-Programming...
