flamecutter wrote: I've been giving this some thought. Jogging the ram is probably one of my main concerns. I'm waiting to see how you have the config working.
You should be able to see jogging in action by using "setp" with the jog-counts pin.flamecutter wrote: I wasn't understanding your jog setup. I was trying to jog it with the sim up down buttons.
Should I add an extra switch to open the hydraulic solenoid valve while jogging or would it be best to let it as it is with the foot switch needing to be pressed to jog. Either way would work for me, but would adding another switch be a safety issue?
I agree that seems best.I believe I would want the ram to stay where it is when exiting jog mode.
Again, with a bit of HAL it can be arranged for both inputs to work.I do have a separate ram up button that is connected to an input. Should this button be used?
I only took this on because it looked like an interesting projectSorry, I feel like I make this complicated for you!
