I'm interested in this. Does anyone have a simulation configuration on this yet?
If you notice on the halscope, that it is applying the offset on index with the home switch active. (edit, the halscope is actually showing the reverse direction. so it is working like it should, but has that fast correction move.)Note how it does not pay any attention to index as long as the axis home-switch it active, so you need to set up some sort of target for the home switch that remains active until just after the last index. (this might be easier with a short target an an inverted input in HAL)
The the machine will run one way until home-switch goes false, then reverse direction and home to the index. You just need to ensure that this ends up always being the same index.
