- Thank you received: 33
andypugh wrote:How would you like it to work? You get to decide
Which encoder do you have? One with distance coding or single index in mid-travel?
Is it an index pulse, or high for half the scale and low for the other half?
Would it be usual to lower "R" then adjust X1, X2, Z1 and Z2? I can see we need more table columns.
I'll need a machine on/off button. I'm used to the axis gui. Do I need the estop button?
I have a physical estop button right at the controls.
Do you want it to? It's simple to change the scale factor of the hm2 encoder.The encoder counts down (negative) as the ram moves down.
Slightly tricky, possibly. How can the system tell which way to go to find the index? (if it's a half-on / half-off track then it is easy)I believe it has single index in mid travel.
My pressbrake does not have the Z axis, only a single X and R
No pictures = never happened !Clive S wrote: I am watching this with interest as I have the friends that is building one.
