flamecutter wrote: Now my next step is to get it to work with my machine. I've been trying to get the press.comp to work in axis gui, but just can't get it going.
Yes, I will need machine on/offAs far as homing goes, now yet I was manuel homing with ram cylinder at top of stroke. Should I be adding a homing switch or is it possible to home off of encoder index?My encoder is an incremental linear encoder.andypugh wrote: Do you need homing? There isn't any homing in my config, it rather depends on an absolute encoder as things stand.There is also nothing controlling machine on/off state or e-stop etc at the moment.
flamecutter wrote: Yes, I will need machine on/off
All things are possible, though if the machine automatically runs to top of travel when off, or always gets parked there, then there might be no need.As far as homing goes, now yet I was manuel homing with ram cylinder at top of stroke. Should I be adding a homing switch or is it possible to home off of encoder index?
flamecutter wrote: Is it an industry standard to have Y axis for the ram, X axis for the bend length, and R axis for raising and lowering the backstop?
