what to do with a free scrap dumpster find ?
4 years 5 months ago #243510 by machinedude
making chip covers is not something i like doing :) but am getting close to having it all sorted out. i now have all my linear scales and 2 out of three of them should be simple to mount i have to think about the Y axis mounting a bit more. i think i figured out why the old covers were giving me a hard time. i should have taken pictures of things before i tore the machine down. i had one of the cover section on wrong and i need to shorten up the guide rods that i replaced they were hitting the base when the travel was almost all the way down.
as for the chip cover on the back i had just enough sheet metal here to make a crude telescoping cover to keep the chips away from getting under everything. i had to resort to attaching some bent end caps since i had next to nothing here to work with. i still have some things to adjust and maybe add some clearance for but they will do what i need them to do for now. i still need to do some kind of skirt on the table to close it up better but it's getting there slowly :).
i have an open section on the original covers that was for grinder stuff. i think i will make a cover and attach a lighted switch there to control the air cylinder for the draw bar. it will be easy to fish some wires around to the back to keep all that stuff organized.
4 years 4 months ago #246088 by machinedude
took a little break from working on this and got back to it this past weekend. i was sorting out oil line needs and picked a few odds and ends up and somehow managed to spend almost $200 for next to nothing :) check valves for oil lines and 10ft of VFD cable was over a $100 ouch :)
sad part is i had some stuff laying around and was able to reuse some of the original stuff and this was the cheapest way out :) i guess the days of being nickeled and dimed to death are a thing of the past :)
4 years 3 months ago - 4 years 3 months ago #247026 by machinedude
Part of the trouble with the oil point connections was the need for some of it to be able to move with the saddle and table on a few of the connections. all the bearing blocks and ball nuts have a M6 x 1.0 hole for the grease fittings they come with. i had a bunch of 10-32 barbed fittings ( will probably need another pack of 10 ) so what i did was get some brass M6 x 1.0 bolts and tap the head so i could attach the barbed fittings and put around a 3mm through hole in the bolt so the oil can flow through it.
i also gutted the old control box and stripped it down bare and put a fresh coat of paint on it to freshen it up some. I got that back on the machine in the original location and ran my VFD cable into this box. the plan is to use this box for the VFD and probably some DC power supplies to keep it away from the sensitive stuff. the braking resistor i will probably mount out side somewhere since they generate some heat. i'm not sure if it would be wise to mount it in the box?
i have check vales for all my oil points too. i just have to sort that end out still. i was try to use the old manifolds for the oil lines needs but i might have to make something custom since i have more points than what was original.
not much progress but the way oil pump in mounted and the lines for the head axis was already done so i reused that part and it's hooked up. the rest i will most likely end up making taking a guess. but here is a few pictures. everyone like pictures :)
Last edit: 4 years 3 months ago by machinedude.
4 years 3 months ago #247027 by tommylight
4 years 3 months ago #247029 by machinedude
either that or good fakes :) it hard to tell sometimes. they were not bought from a dealer so they could be counter fit? china is sneaky like that. you get a lot of counter fit parts floating about sadly.
Time to create page: 0.312 seconds
