had i little bit of time to start the motor mount parts of this build. i have some screw jacks that will attach and act as the belt tension to slide the motor mounting plate on the stand offs. the motor mounting plate just has some slots and a 1/2 13 bolt on both side to lock it in place. the screw jacks are just to lift the motor mount since it has some weight to it to make belt adjust easy.
i also have some new gears to drive the ball screw. i switched to a 2:1 ratio the original set up was 4:1 but that's pretty slow with a 5mm ball screw. i found a drive sizing program from ABB just to get some basic info and it looks like it should work fine. i also picked up some oil seals incase i can fit the gears in a case but space is limited so i have them if i need them. i also picked up a din rail power supply just for the cooling fans not sure if that was the best solution but it was easy enough.
the larger gear will attach to the the ball screw. rather than a key i will just roll pin it to the shaft and use the nut for the ball screw to to lock it down. the set of gears on the left are original and the ones on the right are what i will switch too. simple but should work just as well as being keyed. i have an extra large gear in case i need to do something about backlash as well but will probably see exactly what is going on before i commit to something more complicated.
