Another Biesse Rover 322
4 years 11 months ago - 4 years 11 months ago #225138 by bevins
Replied by bevins on topic Another Biesse Rover 322
OK well, no biggie. Just little bit more work.
You have 4 choices then.
1. Use mesa card with higher output to drive the solenoids directly. Should check the specs first though.
2. build your own board with mosfets to drive the solenoids and contactors.
3. Use regular mesa output boards and ad a physical relay for each output you need.
4. Use the existing rs485 relay modules and modify them to use with mesa board. This entails cutting the pcb traces for the coils and solder wires on them and drive them with mesa outputs.
So with the spindles and aggregates, you will just have to select the correct output from the vfd to route the power to the correct spindle.
Here is a tip that will help you with your journey. Create a spreadsheet with these fields:
Wire#  Description  input output  mesa-card address tested-OK
I'll see if I can find some spreadsheets that I did during some of the Biesse's I converted and upload them.
Then go through every module and fill out the spreadsheet leaving out the mesa card and address at this time. Go through every wire# input and output and find out what it is from the schematics and fill out the spreadsheet. Biesse has sheets for each module and lists wire# and what it is and where the module is located.
This will help during the process a great deal. Then start studying the schematics.
If you need help send me a pdf of the schematics once you scan them.
You can send them to
The Biesse schematics are amazing and so easy once you figure them out.
Last edit: 4 years 11 months ago by bevins.
4 years 11 months ago #225141 by bevins
Here are ones I did for a Biesse Rover 20.  they are excel spreadsheets. Change pdf extensions to  .xlsx.
They wont open if you try with a pdf reader.
4 years 11 months ago #225142 by bevins
One of them is just entering data in from machine and schematics.
The other is adding mesa addressing and how they are connected.
4 years 11 months ago #225146 by bevins
I see you have the Yaskawa CACR Servo Packs, so your motors are probably Yaskawa AC servo's.
The limit switches on the machine goes directly into the drives. and if you hit them you will get POT or PON on the CACR drive and you can just jog off. The home switches go into input modules though. The encoders go into the drives but the drives have encoder outputs that will wire into the 7i77   on the encoder input connectors.
4 years 11 months ago #225148 by ehb
Replied by ehb on topic Another Biesse Rover 322
Thanks - bit of a bummer, but as you say, just a little bit more work.
I just finished scanning the schematics. Module 6 was missing, but I found added documents (from 96) in another folder. Just scanned those too.
I was just doing that - creating a spreadsheet of in- and outputs. :) But I'll now use yours as a basis, seems well organized. Thanks!
This may take a moment :) Some descriptions are only in italien, most in german and italian. So I'm doing some translation, hopefully correctly.
4 years 11 months ago #225150 by ehb
Yes, they are Yaskawa CACR-SR02BE12G-E to be exact.
Thanks for the other information, I'll try to keep everything in mind. :)
