Another Biesse Rover 322
4 years 11 months ago #225037 by bevins
Replied by bevins on topic Another Biesse Rover 322
I forgot to add, if you have to use 7i84 in the field, then you would need to pass Field voltage, which should already be there, and a cat 5 cable for each 7i84 and stick connectors on both ends. control panel end goes to 7i74 the other well, plugs into the 7i84.
The following user(s) said Thank You: ehb
4 years 11 months ago #225038 by bevins
Did I mention these are fun machines to do?  image missing /media/kunena/emoticons/tongue.png
4 years 11 months ago - 4 years 11 months ago #225040 by bevins
Oh and, I have a Biesse 346 with three spindles with only one VFD. It gets selected and routes the moptor cables through the contactor but I think you said you had an aggregate saw which doesnt use the vfd. Like the drill bank there is a motor, through a contactor. You just need to turn on the motor ir drill bank motor contactor via a relay. It is already wired. Thats the beauty, you don't need to tear apart the machine, you just have to deal with the I/O's everything else is already done for you. You need this on? Just fire a relay.
Last edit: 4 years 11 months ago by bevins.
4 years 11 months ago #225041 by bevins
Sorry, done for the evening.... off to pickleball.
4 years 11 months ago - 4 years 11 months ago #225122 by ehb
Replied by ehb on topic Another Biesse Rover 322
Back from the shop with news!
Despite having the RT480, the machine has those rs485 modules if I'm not mistaken. I have located all of them (numbered 0 to 10, with 9 missing in schematics as well). Several pictures attached.
Last edit: 4 years 11 months ago by ehb.
4 years 11 months ago #225124 by ehb
While locating all the modules in the machine, I verified the schematics I have. They're all spot on, which is great. I'll scan them, but I probably shouldn't upload them, for like, copyright issues?
The milling spindles do seem identical and I have a 90° milling aggregate too. Will have to check the schematics, but I bet the VFD drives both.
Unfortunately both the lower and upper guards of the Z spindle have been broken for a long time. Hope the mechanical damage isn't too bad.
