- Thank you received: 5
SIR88 is the rs485 relay inut modules?Hey Bob, great to hear from you!
I might have found out what those limit switches are! They're extra limit switches when using the left and right areas of the machine separately. Milling on one side, placing parts on the other side. So that's something I'm not going to need.They were going to module1 on top of the machine.
Alright, so K125 can stay and should activate all axis by grounding. That's good and easy.
All "Axis OK" originally go to module 7 in the cabinet which is a SIR88. I was under the impression all these modules had sinking inputs, but the ones in the cabinet might be different. I'll look into this a bit more. As you said, a guy can always put a relay in between. Thanks!
And sure I'd like to see your python stuff. If I decide to go the proper route, I'll still be able to deduct some logic from your code, hopefully.
Thanks as always!
