Thanks for pointing this out! You're right, I carelessly assumed P1 (of course 24V) would just "be there" (from the rectifier) when the machine is turned on and P2 and P3 when the machine was put on enable. This is not what happens!
I'm not 100% certain on all of it yet, need some more time to think it through and study the schematics and machine. So please don't pull your hair on my lack of understanding, it takes me some time, sometimes.
I'll have a friend (knowledgable electrician) come over if I can't figure it out, before I hook anything up.
However, by now I realized that the original power supply inside of the original RT480 control comes into play somehow. Since this will go, I need another source of 24V, which should power all of the Mesas VIN and possibly the 7i77's VFIELD too. VFIELD of the other cards could then be P2 and P3 I guess? So the question is where I take this 24V from - from the machines rectifier before all other logic, or from a separate, added, power supply. As I said, still trying to get it together.
Still trying to wrap my head around the labeling of the power supply, why there is 21 V AC and what some things in the schematics are. I'll need to have a fresh look tomorrow, at the machine. I've been staring at page 43 of the schematics for a while...
Re: modules in the cabinet (which both have relays outputs): I already have some Finder DIN rail relays, they work nicely with the Mesa cards (tested).
On another note, the 7i77 looks great in there
