- Thank you received: 286
Means you are running as ROOT, not a user, so some stuff will not work properly, pretty sure LinuxCNC also does not run as root.
sudo "command not found"
The installation method has changed for QTPYVCP and ProbeĀ BAsic. Refer to the relevant forum section here for how tosyou are about 12 posts late
. we are well past that, now im trying to figure out why probe basic isnt starting.
