Mini wannabe datron build
3 years 1 month ago - 3 years 1 month ago #279860 by ihavenofish
Hmmmmm
Last edit: 3 years 1 month ago by ihavenofish.
3 years 1 month ago #279864 by ihavenofish
Oh, correction. the screen is not 7". not sure why i had that stuck in my head. It is 9".... cause i just found they dont sell it anymore, hahaha. they do have a very similar 8" though.
3 years 1 month ago #279871 by besriworld
Looks very good! Black base looks better. Have you tried the virtual keyboard? I will show my lathe project. The screen is small 10.1" . In normal operation it is good to have a knob for speed , spindle speed , rapid travel limit , MPEG .. How will you make the keys , will there be a custom board ? How will you control the digital LEDs ?
3 years 1 month ago #279873 by ihavenofish
Cool!
The keyboard will be a custom pcb that will take cherry switches. The controller is a rp2040 board that will socket in. this will take care of the usb side, as well as "funneling" keystrokes to the mesa.
The LED's are still a mystery as they really need 2 way communication. Torque isnt too hard i think. Read the torque from the drive to the RP2040, translate that into pretty colours on the leds, and trip a pin on the mesa for overload warnings etc and flash leds red etc.
The rest is a bit tricky. if you change mdi mode for example, how does the keyboard know to light that led the right colour. Likewise the override ring. It needs to get that info back from linuxcnc in the form of a number cause all the dial is doing is incrementing.
The global "stale" leds are easier cause they can just be 2 or 3 pins, one for "error", one for "running" and one for "idle" (or maybe a lack of the other 2 means idle). That led is not on the control itself. it is a 50mm long strip i have that will be up high on the door.
I found a new 8" lcd for it. so it got 1 row of keys smaller. I don;t know if i want the lower panel to be smaller though as the key layout is working well.
Pondering haha. :)
3 years 1 month ago - 3 years 1 month ago #279884 by ihavenofish
ok, new 8" screen. keyboard is the same, it just extends to the flange which is not a big deal.
There is nor enough room really on the top now for the mpg features, so it is a fully separate unit. it is still controlled by the rp2040, so it has no "brain" inside of it.
If anyone is wondering why the size constraints and why its 2 pieces. it is partly cause that's all the width there is on the cabinet, and partly because that's the size that can fit in my vise jaws for milling. :) I will be using a big plate of scrap 25mm mic6, so that is dictating some things as well.
3 years 1 month ago #279965 by spumco
Replied by spumco on topic Mini wannabe datron build
I'm not sure what the multiswitch does for me. I have no switches on the mesa.
As you noted you may run in to issues mapping the dedicated control buttons via keystrokes.
As an alternative you might have a look at hal_input.comp to connect the 'second' keyboard (i.e. the dedicated controls) to HAL functions.  Mapping in HAL (vs. GUI keystrokes) would have an added benefit of not being overwritten if you update LCNC.  I've not used this comp, but it looks promising.
If you do go this route all, I mentioned Multiswitch as it is (to me) one of a family of HAL components intended, I think, to increase (or enhance) the number of functions of simple pushbutton inputs.
Multiswitch could be used to consolidate the axis/increment selection in to a single input.  If you ignore the 'down' input, repeatedly pressing the axis button would cycle through the different axes and then roll-over back to the first.  Same thing for the increments.  And one of the selection 'slots' can be left blank to act as an MPG-disabled setting.
Time to create page: 0.162 seconds
