New ethercat / probe basic control for minimonster
29 Oct 2025 17:12 #337417 by Hakan
There is no documentation of registers?
Almost impossible without.
29 Oct 2025 17:24 #337418 by ihavenofish
Replied by ihavenofish on topic New ethercat / probe basic control for minimonster
As I keep poking, I'm finding there are registers now at 8192 range, but they cant be written? 8192 has a value of 6. 8191/ 8193 etc at 0.
Hm
29 Oct 2025 17:55 #337419 by ihavenofish
no documentation at all sadly
29 Oct 2025 18:04 #337420 by ihavenofish
so we have 8192 to 8203. all 0 except 8192 which is 6, and seems not writable. others seem writable but do not induce any change.
i have an idea: i will turn the drive back to panel frequency and run control and see if i can see anything change
29 Oct 2025 18:20 #337423 by ihavenofish
ding ding. so 8192 IS run/stop. goes from 6 to 1. which is true/false im almost positive.
But i don't have a way to write it. every write command says illegal data or address or function (different ones give different errors).
Do i need to tell it it is a true/false register, and not an int/float? if yes, how? i do not see any syntax for that.
thanks for all the help so far, i feel like were getting close, AND i also understand things better.
29 Oct 2025 19:50 - 29 Oct 2025 19:51 #337428 by ihavenofish
ok, sooo
function 3 reads a float and int (6 or 1)
function 1 reads a bit (true/false)
function 5 says illegal function (write coil)
function 6 says illegal data type
What is next to try? I rechecked the vfd settings, and its all "right". Also found out the params are registers (f0.04 = 0Xf004) so that neat. Not actually helpful though.
Last edit: 29 Oct 2025 19:51 by ihavenofish.
29 Oct 2025 20:04 #337430 by Hakan
Do you have a link to the manual?
Maybe there is something helpful in there.
29 Oct 2025 20:26 #337431 by ihavenofish
the manual is for a "slightly different" has no modbus information. my drive is called an HSD7000 and is a nearly identical clone of the innovance, but has modbus built in instead of on an add in card.
md380-inovance-manual.pdf
The add in card manual i am not sure is relevant
Communication Example; Configuration Of Rs485 Communication Between Drive And H5U - Inovance MD38TX1 Series User Manual [Page 50] | ManualsLib
29 Oct 2025 20:47 - 29 Oct 2025 20:48 #337434 by ihavenofish
aha!
looked at that add in card and realised something. it is an int with multiple settings (start, reverse stop, etc). but when the pin initialises it writes a 0, which is not allowed.
so i ignore that and in halshow make it 1 and it turns on. and 6 turns it off.
So now that all makes sense!
The next thing i see is frequency is not 2001, its 1000 (4096 in decimal).
So a quick test of that and we get... motion!
(except its going reverse which is a setting i can change)
woooohooooo
so now, we need a hal and then a spindle section in the ini? because i am using ethercat from scratch here, i have literally no other functions in my main HAL or INI.
What should i be expecting to add there?
Thanks!
Last edit: 29 Oct 2025 20:48 by ihavenofish.
29 Oct 2025 21:31 #337438 by ihavenofish
Should add that the frequency seems to be a percent x 100. so setting it to 100 gives me 13.33 hz which is 1% of full speed.
Gonna need to work that into my math. :)
Time to create page: 0.977 seconds
