dxf2gcode - plasma enhancements
4 years 11 months ago #226032 by Joco
Replied by Joco on topic dxf2gcode - plasma enhancements
That fixed it. Must be the compile flags are too close to the "edge" :-)
4 years 9 months ago #232441 by paulsao
Replied by paulsao on topic dxf2gcode - plasma enhancements
Hello Joco.
Install your modified program, since it allows you to have entries when the compensation is in the computer, that is something that was missing in dxf2gcode, when I saw that the entries were graphed I got excited but when generating the g code, I observe that the entries are after the generation for example of a circle not be generated before? Could you help me please.
F400 G2 X 67.147 Y 67.147 I 17.147 J 17.147
G2 X 32.853 Y 32.853 I -17.147 J -17.147
G1 X 33.913 Y 32.853 ///////////////////////////////////
F150
4 years 9 months ago #232527 by Grotius
Replied by Grotius on topic dxf2gcode - plasma enhancements
@Paulsao,
Could you be more specific about your question?
The following user(s) said Thank You: paulsao
4 years 9 months ago #232552 by paulsao
@ Grotius
I want to use dxf2gcode for plasma cutting, I'm using qtplasmac, and I want to implement some features such as reducing the speed to 60% when cutting circles, I know I can implement using <holes> but I only want to use it for circles and not for all arcs. Yesterday I made some test cuts with the new version where you can modify the inputs and outputs.
4 years 9 months ago #232584 by Joco
I'm operating from memory here as it has been a long time since I looked at this code.  As have been concentrating on monokrom-plasma.
You can have different layers in dxf files and each layer can have tags on it. dxf2gcode know about these layers and uses them for different purposes. I believe you can set feeds/speeds by layer.  You could then have your circles in their own layers with an appropriate feed/speeds tag setting.
You might have to dig about in the code and original site for this layer magic but it is there.
Cheers - J.
Time to create page: 0.186 seconds
