dxf2gcode - plasma enhancements
5 years 5 months ago - 5 years 5 months ago #209547 by Joco
Replied by Joco on topic dxf2gcode - plasma enhancements
tommylight wrote: Just in case you missed this:
forum.linuxcnc.org/31-cad-cam/38379-c-ca...blocks-instead-of-qt
forum.linuxcnc.org/31-cad-cam/39648-free-cadcam-software-tryout
forum.linuxcnc.org/41-guis/36768-qt-c-code-samples
forum.linuxcnc.org/31-cad-cam/36039-c-co...the-building-process
Totally missed it. But looks like things stalled? Not seen much from the author on it since mid last year plus some flicking between QT and codeblocks which looks a bit confusing to me.
I did fork the git repo and got a successful compile after install the obvious QT dev stuff and freeglut3-dev. App powers up and looks super nice. But trying to load a very simple dxf (see attached) is a bust. Saved to R14 and R12 format as well. No errors on command line and nothing appears in the display. Loading the gro fonts samples works.
Using code from: github.com/grotius-cnc/QT_cadcam
off master branch. maybe there is something else I should be using?
So much potential, just not sure where its gotten to. Code looks clean and well structured. Hope it gets some legs back as it looks like it would hold an awesome spot in the 2d space.
Again, thanks for pointing me to it.
Cheers - J.
Last edit: 5 years 5 months ago by Joco. Reason: clarity on code line used.
5 years 5 months ago #209562 by andypugh
Replied by andypugh on topic dxf2gcode - plasma enhancements
Joco wrote: The corner has an extra ultra small line segment that creates a looping back crossed line situation. I have an algorithim that scans around a shape looking at a window of 3 line segments…
On some level I appreciate your approach, but perhaps the real answer is to pop up a box saying "your input file is rubbish at (x,y) complain to the clown who coded your CAD package."
5 years 5 months ago #209569 by tommylight
Replied by tommylight on topic dxf2gcode - plasma enhancements
LOL @ complaining
Grotius is working on ROS and LinuxCNC implementation, so he is always around here.
The following user(s) said Thank You: Joco
5 years 5 months ago #209578 by Joco
It was tempting. But in many ways I am doing this so I have a free tool chain that will support me. I do think you are right that some form of notification would be a good move. So that user is aware that this file has some issues and that some automatic adjustments were made.
Cheers.
5 years 5 months ago #209579 by Joco
tommylight wrote: LOL @ complaining
That is good to know. Clearly a capable and talented chap.
The following user(s) said Thank You: tommylight, Grotius
4 years 11 months ago #225170 by paulsao
Replied by paulsao on topic dxf2gcode - plasma enhancements
Joco can I install your customized version for plasma on windows?
Time to create page: 0.146 seconds
