Gampad in EMC2 Question (SOLVED)
07 Dec 2011 19:45 - 24 Dec 2011 17:08 #15454 by cwebs
Gampad in EMC2 Question (SOLVED) was created by cwebs
I would like to add a gampad to my machine. Will this program work to set pad to keys?
qjoypad.sourceforge.net/#download
If not then what might be the easy way for a duma$$ to set it up? Thanks Carl
Last edit: 24 Dec 2011 17:08 by cwebs.
07 Dec 2011 20:14 #15457 by Rick G
Replied by Rick G on topic Re:Gampad in EMC2 Question
07 Dec 2011 20:26 #15458 by cwebs
Replied by cwebs on topic Re:Gampad in EMC2 Question
Rick G wrote:
Have you looked here?
wiki.linuxcnc.org/emcinfo.pl?Simple_Remote_Pendant
Rick G
Yes I have looked at this site and everyone I can find, BUT, I know NOTHEN about installing and setup without a GUI. The last time I tried to follow the instruction for gambad setup EMC2 would not start. Scared me silly and I went off screeming like a little girl. If I set up a gampad for gaming would that setup carry over to EMC2 or does it HAVE to be in HAL? Carl
07 Dec 2011 20:31 #15460 by Rick G
Going to need hal
But it is worth it to get the gamepad working and you will learn a lot.
You might want to save your current configuration and start a new one to try.
If you get stuck look at the error messages and we can probably help.
Rick G
07 Dec 2011 20:35 #15461 by cwebs
Rick G wrote:
Going to need hal
Rick G
OK, RIck. But if/when it goes up in smoke I will know who to blame. Carl
12 Dec 2011 19:49 #15604 by cwebs
cwebs wrote:
Rick G wrote:
Going to need hal
Rick G
Hay Rick, it went up in smoke. I am trying to follow the "Simple Remote Pendent" instructions and got lost with the name. My gampad is named "Mackintosh" and I could not see where you put the name. I undid every thing I put in the HAL and ini files and got the program working again.
12 Dec 2011 20:38 #15606 by BigJohnT
Replied by BigJohnT on topic Re:Gampad in EMC2 Question
Instead of
loadusr -W hal_input -KRAL Dual
try
loadusr -W hal_input -KRAL Mackintosh
Make sure that step works before you proceed.
13 Dec 2011 16:39 #15634 by cwebs
BigJohnT wrote:
Instead of
try
loadusr -W hal_input -KRAL Macintosh
First step doesn't work. No mater what I try for name it won't EMC won't start. Removing, -KRAL Macintosh , will let EMC start. Carl
13 Dec 2011 16:42 #15635 by cwebs
How do I copy and paste the error info? I am unable to copy the message. Carl
13 Dec 2011 17:09 #15637 by andypugh
Replied by andypugh on topic Re:Gampad in EMC2 Question
Select and Ctl-C?
What is the output of
less /proc/bus/input/devices
(the very first step of the process)
Time to create page: 0.083 seconds
