Gampad in EMC2 Question (SOLVED)
13 Dec 2011 19:18 #15641 by cwebs
Replied by cwebs on topic Re:Gampad in EMC2 Question
andypugh wrote:
cwebs wrote:
How do I copy and paste the error info? I am unable to copy the message. Carl
Select and Ctl-C?
What is the output of
less /proc/bus/input/devices
(the very first step of the process)
I: Bus=0017 Vendor=0001 Product=0001 Version=0100
N: Name="Macintosh mouse button emulation"
P: Phys=
S: Sysfs=/devices/virtual/input/input0
U: Uniq=
H: Handlers=mouse0 event0
B: EV=7
B: KEY=70000 0 0 0 0 0 0 0 0
B: REL=3
I: Bus=0011 Vendor=0001 Product=0001 Version=ab41
N: Name="AT Translated Set 2 keyboard"
P: Phys=isa0060/serio0/input0
S: Sysfs=/devices/platform/i8042/serio0/input/input1
U: Uniq=
H: Handlers=kbd event1
B: EV=120013
B: KEY=4 2000000 3803078 f800d001 feffffdf ffefffff ffffffff fffffffe
B: MSC=10
B: LED=7
I: Bus=0003 Vendor=413c Product=3010 Version=0100
N: Name="HID 413c:3010"
P: Phys=usb-0000:00:10.0-1/input0
S: Sysfs=/devices/pci0000:00/0000:00:10.0/usb1/1-1/1-1:1.0/input/input2
U: Uniq=
H: Handlers=mouse1 event2
B: EV=17
B: REL=103
B: MSC=10
I: Bus=0010 Vendor=001f Product=0001 Version=0100
N: Name="PC Speaker"
P: Phys=isa0061/input0
S: Sysfs=/devices/platform/pcspkr/input/input3
U: Uniq=
H: Handlers=kbd event3
B: EV=40001
B: SND=6
I: Bus=0003 Vendor=0079 Product=0006 Version=0110
N: Name="DragonRise Inc. Generic USB Joystick "
P: Phys=usb-0000:00:10.2-1/input0
S: Sysfs=/devices/pci0000:00/0000:00:10.2/usb3/3-1/3-1:1.0/input/input4
U: Uniq=
H: Handlers=event4 js0
B: EV=1b
B: KEY=fff 0 0 0 0 0 0 0 0 0
B: ABS=3002f
13 Dec 2011 19:28 #15643 by cwebs
This is the error I get
Print file information:
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_BIN_DIR=/usr/bin
EMC2_TCL_DIR=/usr/share/emc/tcl
EMC2_SCRIPT_DIR=
EMC2_RTLIB_DIR=/usr/realtime-2.6.24-16-rtai/modules/emc2
EMC2_CONFIG_DIR=
EMC2_LANG_DIR=/usr/share/emc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
EMC2_EMCSH=/usr/bin/wish8.4
EMC2 - 2.4.6
Machine configuration directory is '/home/carl/emc2/configs/Carl's_CNC'
Machine configuration file is 'Carl's_CNC.ini'
INIFILE=/home/carl/emc2/configs/Carl's_CNC/Carl's_CNC.ini
PARAMETER_FILE=emc.var
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=halui
DISPLAY=axis
NML_FILE=
Starting EMC2...
Starting EMC2 server program: emcsvr
Starting EMC2 IO program: io
Shutting down and cleaning up EMC2...
Killing task emcsvr, PID=5800
Cleanup done
Debug file information:
No input devices could be opened. This usually indicates a misconfigured
system. Please read the section 'PERMISSIONS AND UDEV' in the hal_input
manpage
Carl's_CNC.hal:97: hal_input exited without becoming ready
5800
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 2316.337910] I-pipe: Domain RTAI registered.
[ 2316.337923] RTAI[hal]: <3.6.1> mounted over IPIPE-NOTHREADS 2.0-04.
[ 2316.337926] RTAI[hal]: compiled with gcc version 4.2.4 (Ubuntu 4.2.4-1ubuntu3).
[ 2316.337931] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 2316.337934] PIPELINE layers:
[ 2316.337936] dcca4000 9ac15d93 RTAI 200
[ 2316.337938] c0383180 0 Linux 100
[ 2316.352023] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 2316.352533] RTAI[sched]: loaded (IMMEDIATE, UP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 2316.352538] RTAI[sched]: hard timer type/freq = 8254-PIT/1193180(Hz); default timing: periodic; linear timed lists.
[ 2316.352542] RTAI[sched]: Linux timer freq = 250 (Hz), CPU freq = 2165046000 hz.
[ 2316.352545] RTAI[sched]: timer setup = 2010 ns, resched latency = 2689 ns.
[ 2316.432566] RTAI[math]: loaded.
[ 2316.564234] config string '0x378 out '
[ 2317.376295] RTAI[math]: unloaded.
[ 2317.437365] SCHED releases registered named ALIEN RTGLBH
[ 2317.451441] RTAI[malloc]: unloaded.
[ 2317.550675] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 2317.553674] I-pipe: Domain RTAI unregistered.
[ 2317.553683] RTAI[hal]: unmounted.
  • andypugh
  • andypugh's Avatar
  • Moderator
  • Moderator
13 Dec 2011 21:01 #15645 by andypugh
Replied by andypugh on topic Re:Gampad in EMC2 Question
This isn't it.
This is it. Try
loadusr -W hal_input -KRAL DragonRise
13 Dec 2011 21:06 #15646 by cwebs
andypugh wrote:
This isn't it.
This is it. Try
Sorry but after that post thinking Macintosh was it I went back and see I was wrong. I did try DragonRise with the same problem. I also tried Joystick from that "name". Carl.
  • andypugh
  • andypugh's Avatar
  • Moderator
  • Moderator
13 Dec 2011 21:52 #15649 by andypugh
The error message suggests it might be a problem with the udev and permissions, did they all happen as described?
13 Dec 2011 21:59 #15650 by cwebs
To the best of my knowlage, yes. I am compleatly lost with the coding and have been reading the HAL manual. I am getting low on hair. Been pulling it out over this. Not enought for a comb over now. Carl
13 Dec 2011 22:51 #15651 by cwebs
3. Step 3 Add the hal_input
In your .hal file (the main one) add the following
# for remote joypad
loadusr -W hal_input -KRAL Dual
In your .ini file in the [HAL] section add the following line if you don't have it
HALUI = halui
The instruction for step 3 says "In your .hal file (the main one). Where is the "main one"? I see on another post that it goes in the .ini . Carl
  • andypugh
  • andypugh's Avatar
  • Moderator
  • Moderator
13 Dec 2011 23:13 #15652 by andypugh
Actually, I think it can go in any of the HAL files. But how many do you have? (referenced in the INI file, in the folder in <home>emc2/configs/<the name of your machine>
No, you just need to check that HALUI = halui appears in the [HAL] section of your INI file.
14 Dec 2011 01:41 #15654 by cmorley
Replied by cmorley on topic Re:Gampad in EMC2 Question
You could use PNCconf to help you make and test the rule for joysticks.
At least then you would know if it works or not.
Its pretty easy to try even if it doesn't work.
on the external controls page select 'USB joystick jogging'
then select 'details'
select add rule - follow the prompts - you need your joystick
after your done you can select 'test device'
it will load the device with HAL_INPUT and start a halmeter so you can test the joystick
14 Dec 2011 10:54 #15671 by Rick G
Replied by Rick G on topic Re:Gampad in EMC2 Question
Did you have to add this?
If your system won't recognize the joypad you might have to look at hal_input man page and perhaps modify the permissions to access the device. Prepared a one line file as per the description in the man page.
SUBSYSTEM=="input", mode="0660", group="plugdev"
Name the file 51-plugdev.rules and save it in /etc/udev/rules.d
From the bottom of...
wiki.linuxcnc.org/emcinfo.pl?Simple_Remote_Pendant
Chris,
That is a neat idea, I will have to try that.
Rick G
Time to create page: 1.718 seconds
