4th Axis rotation angle limit problem
14 years 6 months ago #19347 by SvenH
Ok, awesome you (and maybe others) are willing to have a look!
Here is the sample config, made fresh from a working 4axis configuration, just the spindle added.
File Name: config_clean.zip
File Size:5.76 KB
14 years 6 months ago #19360 by andypugh
I have fiddled the INI and HAL.
Now M3 S10 (for example) will start the A axis moving. M5 will (probably) stop it moving.
This _only_ allows A to work as a lathe spindle, but it ought to be possible to configure such that A acts as an axis when the "spindle" is stopped by switching modes on spindle.is-on. Let me know if you want me to try that.
File Name: CNC_XYZ_A_lathe.zip
File Size:4.48 KB
14 years 6 months ago #19361 by SvenH
Thanks a lot Andy!
I'll give it a spin tomorrow.
14 years 6 months ago #19369 by SvenH
Hi Andy,
Gave it a try, the 4th will not move but the spindle controls in axis say the "spindle" does respond.
I tried to look up if the pins are ok but could not find any reference that seemed to be incorrect to my very limited understanding :)
I noticed that on line 8 of .hal you give loadrt stepgen ctrl_type=p,p,p,v step_type=0,0,0,0 where I would expect loadrt stepgen ctrl_type=p,p,p,v step_type=0,0,0,1. (expected because of reading it, not understanding of any kind..)
14 years 6 months ago #19370 by andypugh
Ah, yes. And I know why. I forgot to connect the stepgen to the parport. You need to add:
net astep <= stepgen.3.step
net adir <= stepgen.3.dir
to the HAL.
step_type 1 is up/down, not step and direction. Is the A-axis stepper drive of a different type?
Note that you probably need to alter the [AXIS_3] scale in the INI to get the right mapping between S and actual rpm.
14 years 6 months ago #19372 by SvenH
Woohaaaaaaaaaaaaaaaaaaaaaa!
It works!
At least with the manual commands in axis
Now lunch and then try it with a program!
Thanks a lot Andy!
Time to create page: 0.073 seconds
