4th Axis rotation angle limit problem
8 years 11 months ago #101512 by andypugh
eFalegname wrote: I have another question, how can I command the rpm of the A axis with M66 P0 ?
Thanks very much for your time and dedication
You ned something like
net a-vel-cmd motion.analogout-00 => stepgen.4.velocity-cmd
8 years 11 months ago - 8 years 11 months ago #101573 by eFalegname
Hi Andy,
sorry for bothering you again mate, let me know please where I'm failing:
1- M64 P0 from MDI windows turns the velocity mode ON,
2- then I write M68 E0 Q20000 code and pass the speed value 20000,
3- save the value of the parameter #5399 in the variable #1 (#1=#5399),
4- at this point I type A#1, or whatever else and A axis doesn't move anymore...
I don't know how to spin the 4th axis, please help me.
Floris
PS: I added:
net a-vel-cmd motion.analog-out-00 => stepgen.4.velocity-cmd
to my .hal configuration
Last edit: 8 years 11 months ago by eFalegname.
8 years 11 months ago #101583 by andypugh
Is the stepgen enabled?
8 years 11 months ago #101590 by eFalegname
Good morning Andy!
I added the enable signal to my "3rd axis" and now the 4th axis is alive:
setp stepgen.3.position-scale [AXIS_3]SCALE setp stepgen.3.steplen 1 setp stepgen.3.stepspace 1 setp stepgen.3.dirhold 27000 setp stepgen.3.dirsetup 27000 setp stepgen.3.maxaccel [AXIS_3]STEPGEN_MAXACCEL net apos-cmd axis.3.motor-pos-cmd => stepgen.3.position-cmd net apos-fb stepgen.3.position-fb => axis.3.motor-pos-fb ###################################################################### net aenable axis.3.amp-enable-out => stepgen.3.enable stepgen.4.enable ###################################################################### ########################################### setp stepgen.4.position-scale [AXIS_4]SCALE setp stepgen.4.steplen 1 setp stepgen.4.stepspace 1 setp stepgen.4.dirhold 27000 setp stepgen.4.dirsetup 27000 setp stepgen.4.maxaccel [AXIS_4]STEPGEN_MAXACCEL net a-vel-cmd motion.analog-out-00 => stepgen.4.velocity-cmd ############################################################
I have another one problem to resolve,
I type the following command in the MDI windows:
1- M64 P0, active the speed mode
2- M68 E0 Q2000,command the speed value to the axis
3- M65 P0, I turn off the axis and switch to the position mode
4- M64 P0, I active again the speed mode, and the stepping motor suddenly and always stall
5- Anytime I type (debug, #5399) the answer is 0
6- At this point any other Q value of M68 I write on the MDI does not change the speed of the motor that remains blocked, to restore all this I have to restart my Linuxcnc
8 years 11 months ago #101592 by andypugh
I think this is likely to be due to the stepgen accel rates. What happens if you do M68 E0 Q0 before switching to position mode, and then only set the speed after switching to velocity mode?
The robust way to do this is probably to only enable each stepgen when the corresponding mode is active. Then the stepgens will ramp up speed inside their own limits.
8 years 11 months ago - 8 years 11 months ago #101596 by eFalegname
Yes, M68 E0 Q0 works, but I can't do any velocity changes before M65.
I changed my settings without succes:
setp stepgen.3.position-scale [AXIS_3]SCALE setp stepgen.3.steplen 1 setp stepgen.3.stepspace 1 setp stepgen.3.dirhold 27000 setp stepgen.3.dirsetup 27000 setp stepgen.3.maxaccel [AXIS_3]STEPGEN_MAXACCEL net apos-cmd axis.3.motor-pos-cmd => stepgen.3.position-cmd net apos-fb stepgen.3.position-fb => axis.3.motor-pos-fb net aenable axis.3.amp-enable-out => stepgen.3.enable setp stepgen.4.position-scale [AXIS_4]SCALE setp stepgen.4.steplen 1 setp stepgen.4.stepspace 1 setp stepgen.4.dirhold 27000 setp stepgen.4.dirsetup 27000 setp stepgen.4.maxaccel [AXIS_4]STEPGEN_MAXACCEL net a-vel-cmd motion.analog-out-00 => stepgen.4.velocity-cmd #################### sept stepgen.4.enable 1 ####################
I have not idea on how to enable each signal of the "[AXIS_4]" only with the velocity mode, maybe I have to add "stepgen.4.enable" to the mux function? Should I change the value of the signals to 0 and activate them with the mux function?
Time to create page: 0.183 seconds
