- Thank you received: 30
Does it mean that it is necessary to address this problem in a completely different way?The stepgens in mesa hardware are built into the firmware and wired to fixed interface pins
( which pins are determined by the particular firmware used )
you do not control them at the pin level but rather by position or velocity commands
eFalegname wrote: I found this answer given by PCW about the mesa stepgen pin:
