4th Axis rotation angle limit problem
07 Nov 2017 15:01 #101507
Replied by andypugh on topic Woohaaaaaa:4th Axis rotation angle limit problem
What isn't working? It looks basically OK.
- eFalegname
- Thank you received: 30
07 Nov 2017 16:40 - 07 Nov 2017 16:41 #101509
by eFalegname
Replied by eFalegname on topic Woohaaaaaa:4th Axis rotation angle limit problem
Hi Andy
Thanks for your prompt answer. I use the Iso experimental version debian stretch, when linuxcnc doesn't reboot there is not error window that tells what problems there are. After I compile the custom.hal file with mux component linuxcnc doesn't run anymore and I can't see what is the problem. Please take a look to the files I attached because I can't find my errors.
Thank you
Floris
Thank you
Floris
Last edit: 07 Nov 2017 16:41 by eFalegname.
07 Nov 2017 17:10 #101510
If you start Linuxcnc from the command line (command "linuxcnc") then you should get at least _some_ output giving a hint as to the nature of the problem.
- eFalegname
07 Nov 2017 17:52 - 07 Nov 2017 17:56 #101511
by eFalegname
Hi Andy
I did as you told me. The errors were these two lines below
net astep <= stepgen.3.step
net adir <= stepgen.3.dir
disconnecting these two functions linuxcnc started as normal (I don't try to run it on the cnc yet)
I have another question, how can I command the rpm of the A axis with M66 P0 ?
Thanks very much for your time and dedication
setp stepgen.3.position-scale [AXIS_3]SCALE
setp stepgen.3.steplen 1
setp stepgen.3.stepspace 1
setp stepgen.3.dirhold 27000
setp stepgen.3.dirsetup 27000
setp stepgen.3.maxaccel [AXIS_3]STEPGEN_MAXACCEL
net apos-cmd axis.3.motor-pos-cmd => stepgen.3.position-cmd
net apos-fb stepgen.3.position-fb => axis.3.motor-pos-fb
#net astep <= stepgen.3.step
#net adir <= stepgen.3.dir
net aenable axis.3.amp-enable-out => stepgen.3.enableI have another question, how can I command the rpm of the A axis with M66 P0 ?
Last edit: 07 Nov 2017 17:56 by eFalegname.
07 Nov 2017 18:03 #101512
You ned something like
net a-vel-cmd motion.analogout-00 => stepgen.4.velocity-cmd
- eFalegname
09 Nov 2017 11:17 - 09 Nov 2017 11:37 #101573
by eFalegname
Hi Andy,
sorry for bothering you again mate, let me know please where I'm failing:
1- M64 P0 from MDI windows turns the velocity mode ON,
2- then I write M68 E0 Q20000 code and pass the speed value 20000,
3- save the value of the parameter #5399 in the variable #1 (#1=#5399),
4- at this point I type A#1, or whatever else and A axis doesn't move anymore...
I don't know how to spin the 4th axis, please help me.
Floris
PS: I added:
net a-vel-cmd motion.analog-out-00 => stepgen.4.velocity-cmd
to my .hal configuration
Floris
PS: I added:
Last edit: 09 Nov 2017 11:37 by eFalegname.
09 Nov 2017 17:26 #101583
Is the stepgen enabled?
- eFalegname
10 Nov 2017 04:34 #101590
by eFalegname
Good morning Andy!
I added the enable signal to my "3rd axis" and now the 4th axis is alive:
I have another one problem to resolve,
I type the following command in the MDI windows:
1- M64 P0, active the speed mode
2- M68 E0 Q2000,command the speed value to the axis
3- M65 P0, I turn off the axis and switch to the position mode
4- M64 P0, I active again the speed mode, and the stepping motor suddenly and always stall
5- Anytime I type (debug, #5399) the answer is 0
6- At this point any other Q value of M68 I write on the MDI does not change the speed of the motor that remains blocked, to restore all this I have to restart my Linuxcnc
net aenable axis.3.amp-enable-out => stepgen.3.enable stepgen.4.enable
setp stepgen.4.position-scale [AXIS_4]SCALE
setp stepgen.4.steplen 1
setp stepgen.4.stepspace 1
setp stepgen.4.dirhold 27000
setp stepgen.4.dirsetup 27000
setp stepgen.4.maxaccel [AXIS_4]STEPGEN_MAXACCEL
############################################################I have another one problem to resolve,
10 Nov 2017 04:58 #101592
I think this is likely to be due to the stepgen accel rates. What happens if you do M68 E0 Q0 before switching to position mode, and then only set the speed after switching to velocity mode?
The robust way to do this is probably to only enable each stepgen when the corresponding mode is active. Then the stepgens will ramp up speed inside their own limits.
- eFalegname
10 Nov 2017 05:42 - 10 Nov 2017 05:58 #101596
by eFalegname
Yes, M68 E0 Q0 works, but I can't do any velocity changes before M65.
I changed my settings without succes:
I have not idea on how to enable each signal of the "[AXIS_4]" only with the velocity mode, maybe I have to add "stepgen.4.enable" to the mux function? Should I change the value of the signals to 0 and activate them with the mux function?
sept stepgen.4.enable 1
####################I have not idea on how to enable each signal of the "[AXIS_4]" only with the velocity mode, maybe I have to add "stepgen.4.enable" to the mux function? Should I change the value of the signals to 0 and activate them with the mux function?
Last edit: 10 Nov 2017 05:58 by eFalegname.
