orientation linuxcnc
14 years 2 months ago #23041 by dangercraft
Replied by dangercraft on topic Re:orientation linuxcnc
Viloria,
Todos los servo motores son identicos? Esa maquina debe llevar por lo minimo 4 servos, mas el motor del husillo (que tambien pudiera ser un servo, ) mas los dos motores de los cambiadores de las torretas, mas el posicionador de barra. A lo que me referia es que le tomes ls datos a todos los motores para que podamos ver que tenemos entre manos.
Saludos,
Francisco
14 years 2 months ago #23043 by jlviloria
Replied by jlviloria on topic Re:orientation linuxcnc
Francisco.
Bueno ya entrando en materia:
tiene 2 servomotores 22Nm, 32.4 A -- 2000rpm
tiene 2 servomotores 12Nm , 25.5 A --- 3000rpm
El motor del husillo, RPM MAX 3500, 50HP, 185 AMPS, 220Voltios
Los motores de las torretas no logro verlos, pero quiero agregarles servomotores. claro que aun sin ver un presupuesto.
Amigo yo pienso que puede quedar bien con unos servos de menos potencias 1.5Kws como los que me escribiste en el hilo anterior. cual es tu recomendacion
gracias.
Jorge image missing http://www.linuxcnc.org/media/kunena/attachments/legacy/images/2012_06_29_10-5b17f75b922b0d3b474f72a638c4ef20.jpg
14 years 2 months ago #23045 by BigJohnT
Replied by BigJohnT on topic Re:orientation linuxcnc
dangercraft wrote:
I'll answer in Spanish and then translate in case any wants to read, if this needs to move to the Spanish forum section I'm sure someone will let me know.
Would you be interested in being a moderator on the Spanish sub forum? All that means is you get an email if someone posts a message there...
14 years 2 months ago #23046 by jlviloria
Jhon,
Recommendation that you give me your ...
the idea is to work the machine. Please servomotor and drive which are the need.
thank you very much beforehand.
jorge viloria
14 years 2 months ago #23047 by dangercraft
John,
I wouldn't mind helping out with that. What responsibilities does the job entail (you can PM me if you want so as not to hijack the thread)?
Frank
14 years 2 months ago #23048 by dangercraft
Viloria,
Me pudieses enviar los datos del torno, Modelo, año, serie etc.?
Francisco
Time to create page: 0.241 seconds
