- Thank you received: 9
It hurts my limitation in language. information is lost because of you-googletraductor-yo, you lose 25% of the information
In that case it ought to be fairly easy to run the motors from an 8i20. I am still hoping that PCW will say whether he thinks that is a good plan or not though.I read the information you sent me, the engine has "hall sensor", anyway send an email to support Siemens to confirm.
That is an excellent idea. Almost nobody keeps their first idea of a config, far better to learn what you really need with a cheap parallel-port system than with a costly servo board set.4. of linuxcnc, I'm making an interface, drives with 3 stepper motors. small (hooby), to familiarize myself more with the software linuxcnc.
That's all really easy stuff. In most cases there are several solutions.5. something that has me worried is the integration of buttons on the machine.
to open and close the chuck, to turn on the pump, cycle start and feed hold .. but I think that will come with time.
