orientation linuxcnc
14 years 2 months ago #23031 by PCW
Replied by PCW on topic Re:orientation linuxcnc
Those look like AC servos with ac tachometers, so may be hard to find matching drives. Are the existing drives known to be bad or are they just missing?
14 years 2 months ago #23032 by jlviloria
Replied by jlviloria on topic Re:orientation linuxcnc
engineer,
the idea is to change the whole system.
linuxcnc use, servomotor new or used but in good condition. with its own servodrive.
the big question I have is to select the best option and is compatible with linuxcnc. I have been speaking board 5I25 7I37 MESA, but unfortunately I have not found information on these board.
in conclusion do not know which servo motor, servo drive and interface used. linuxcnc compatible with, that are good for the machine, and which are not so expensive.
please help me select the best option.
no matter that only use a turret, I'm content with that.
very much thanks for you colaboration image missing http://www.linuxcnc.org/media/kunena/attachments/legacy/images/2012_08_10_09-1a04b2ce366e3bee7e5be35240948d9a.jpg
14 years 2 months ago - 14 years 2 months ago #23034 by dangercraft
Replied by dangercraft on topic Re:orientation linuxcnc
I'll answer in Spanish and then translate in case any wants to read, if this needs to move to the Spanish forum section I'm sure someone will let me know.
Sr. Viloria,
Usted puede verificar si los amplificadores (drives) de los servomotores estan funcionales? Lo primero que yo intentaria seria esto. Si los amplificadores estan funcionales solo es cuestion de identificar cuales son las funcionalidades que usted requiere y con eso vemos que tipo de interface se utiliza entre el control (linuxcnc) y los amplificadores. Esto puede ser tanto una tarjeta MESA, como un par o mas de tarjetas parallelas. La decicion ya recaeria en su presupuesto y la funcionalidad que le quiere sacar al torno.
Me avisa.
Saludos cordiales,
Frank Perez en Panama
<translate> Can you verify if the drives are functional? Thats the first thing I would try. If the drives are functional its just a question of identifying what functionalities you want from the lathe to choose an interface to linuxcnc. This could be a mesa setup or a couple or few paraport cards. What direction you go is going to depend on what your reuiqrements and budget are. </translate>
Last edit: 14 years 2 months ago by dangercraft.
14 years 2 months ago #23036 by jlviloria
Amigo, Frank.
Muchas gracias por tu respuesta.
te cuento que los servodrive no sirven para nada, los servomotores han soportado mucha agua. esta maquina ha estado a sol y agua por 3 años.
Mi jefe me la regalo. 800 dolares.!!!
se que no es facil hacer un retrofit pero lo quiero hacer por aprendizaje y obvio para ver si la puedo poner a trabajar.
mira solo cuento con la parte mecanica. estoy dispuesto a cambiar servomotor y servodrive.
pero el problema es que no tengo idea de cual es mejor y cual se adapta mejor a linuxcnc. la maquina trae motores de ac servomotor 23Nm, pero se que un servo de esas especificaciones debe ser costoso. no importa si pierdo rapidez o torque. me interesa ponerla a trabajar y hacer el desarrollo. la maquina tiene dos torretas osea 4 ejes no importa si solo pongo a trabajar 1 torreta osea 2 ejes... ya eso seria ganancia.
quiero saber que puedo.. y se que aqui encontrare apoyo de todos ustedes..
gracias de nuevo.
atento a tu respuesta. image missing http://www.linuxcnc.org/media/kunena/attachments/legacy/images/2012_08_10_09-f57db170f6196be054432ad10ddc0eb7.jpg
14 years 2 months ago #23039 by dangercraft
Viloria,
En realidad este no es un proyecto complicado, pero pienso que debes tener claro que no es algo que uno nomeralmente utilizaria como proyecto de aprendizaje. La complejidad se vera aparente cuando intente controlar las dos torretas a la misma ves, ya que una torreta a la ves es lo mismo que nadamas tener una sola torreta en terminos de produccion.
Un servo de 23 NM es approximadamente un servo de 5Kw. Si yo fuera adivino, yo diria que este servo de 5kw es el de el eje del husillo, ya que la mayoria de estas maquinas utilizan servos de 1.5kw a 3 kw en los ejes. Si me hiciezes el favor de verificar y tal ves tomarles fotos a las plaquetas de los servos, nos seria de mucha ayuda.
Frank
14 years 2 months ago #23040 by jlviloria
Amigo, gracias por tu respuesta.
Pues complejo para mi que nunca lo he hecho. pero de todas maneras quiero verla operativa.
esta es la placa de los servos.
seria genial hacer trabajar las torretas al tiempo pero bueno habrá tiempo para eso.
Lo primero es hacer la buena selección de los servomotores y los drives y hacerla andar. algo que me tiene pensando es hacer que la torreta haga cambio de herramientas, pero como te digo, primero lo primero.
eres muy amable con tu respuesta, gracias por tu tiempo.
cordialmente
Jorge Viloria
Barranquilla Colombia image missing http://www.linuxcnc.org/media/kunena/attachments/legacy/images/2012_06_29_10-81509640f875dedc5c2e018e19ff60a2.jpg
Time to create page: 0.856 seconds
