Can anyone recommend a new motherboard?
- Thank you received: 4966
15 Dec 2012 07:36 - 15 Dec 2012 07:38 #27744
I am using that driver on my machine and I did _not_ need to recompile the kernel.
I think you should just need to open the downloaded driver and run the setup script. (ie, go straight to section 3)
Replied by andypugh on topic Re:Can anyone recommend a new motherboard?
yes I have download the driver for linux from home.eeti.com.tw/web20/eGalaxTouchDriver/linuxDriver.htm and in the guide say that use make menuconfig for activate EVDEV UINPUT and HIDRAW and rebuild my kernel to make it effect
Last edit: 15 Dec 2012 07:38 by andypugh.
- diegoroman17
15 Dec 2012 07:49 #27746
by diegoroman17
Replied by diegoroman17 on topic Re:Can anyone recommend a new motherboard?
I have installed the drive without recompile kernel but it don't work
Or is necessary active it or any magic???
How can you do work it?
please help me I have try it for 10 hours without obtain any result
15 Dec 2012 07:52 #27747
I recall it took some effort.
I had to make an Xorg.conf file, then fiddle about with the settings that the setup.sh script put in there.
Does the setup script run without errors?
15 Dec 2012 07:56 - 15 Dec 2012 07:57 #27748
samiux.blogspot.co.uk/2010/07/howto-ubun...abyte-touchnote.html
But you shouldn't need the calibrator, I used the one provided by eeti and it worked fine.
Last edit: 15 Dec 2012 07:57 by andypugh.
- diegoroman17
15 Dec 2012 08:14 #27749
by diegoroman17
yes. It execute without errors but restart linux and the touch don't work. I use eGTouchU for calibrate and in it appear the usb driver but when I try 4 point calibration apear the screen blue with a point I touch it and not do nothing. How I can do the Xorg?
- diegoroman17
15 Dec 2012 08:55 #27750
by diegoroman17
The instructions of link samiux.blogspot.co.uk/2010/07/howto-ubun...abyte-touchnote.html should do with the driver installed or without this? I try with the driver installed and my linux die
after the reboot
Linux try boot but it only show a black screen. Now I am installing a new linux
- diegoroman17
15 Dec 2012 23:07 #27770
by diegoroman17
Now it work
I have implemented the link without install the driver of eeti. Now can I install the driver? or exist any conflict. How I can calibrate the touch? support it right click?
16 Dec 2012 00:10 #27771
This is a Linux question, really, not a LinuxCNC question.
You might find answers with Google.
I was going to give you my Xorg.conf file, but rather surprisingly I don't have one (and I do have a working touchscreen), using the eGalaxtouch32 drivers.
I also don't seem to have any of the suggested entries in my blacklists, so I don't know what I did to make the touchscreen work (shrug)
Have you tried sudo sh setup.sh as eeti suggest?
Now it work
- BigJohnT
- Thank you received: 1176
16 Dec 2012 00:22 #27773
by BigJohnT
Replied by BigJohnT on topic Re:Can anyone recommend a new motherboard?
This is how I calibrated my touch screen.
linuxcnc.org/index.php/english/forum/41-...en-gui?start=6#27426
16 Dec 2012 00:33 #27774
But that is a different type (ELO , not EETI) so that might make things worse.
This is how I calibrated my touch screen.linuxcnc.org/index.php/english/forum/41-...en-gui?start=6#27426
