Running Linuxcnc
  • MakingToothpicks
  • Senior Member
  • Senior Member
27 May 2013 07:00 #34741 by MakingToothpicks
Running Linuxcnc was created by MakingToothpicks
I have finished with the stepconfg wizard. I started the program. I cannot get the machine to move on any axis.
I have a bed that is 2'x4' if I place a piece to cut in the center I need the router to move to this piece so I can set
the 0 points. I think. The motors make sounds like they are energized but they do not move. I have seen videos
showing people moving their machines to a specific spot to start cutting. When I use the keys I see the image
of the router head moving in the graphics window. All axis move in stepconfg.
Thank You for your patience and indulgences.
Don
PS : I really would like to see this machine move some day LoL :evil:
27 May 2013 09:59 #34743 by cmorley
Replied by cmorley on topic Running Linuxcnc
Well you give us little to go by.
like saying to the mechanic 'my car won't start - what's wrong?' :)
Did you test the axes in stepconf?
What did you do in the screen to get started?
What screen are you using?
Chris M
The following user(s) said Thank You: MakingToothpicks
  • MakingToothpicks
  • Senior Member
  • Senior Member
27 May 2013 11:23 #34744 by MakingToothpicks
Replied by MakingToothpicks on topic Running Linuxcnc
What I meant by done with stepconfg is that X Y and Z axis all work using jog shuttle button. I can also hit the run button and it runs that axis until I stop it.
I then start the program on my dest top using the machine name I created. The start screen appears to be Axis. It has linuxcnc in the preview window. It says this is not for cutting. I load an nc created in the program using a jpg image. I can get the manual control active. I see the little icon for the spindle moves when I use the arrow keys but the gantry does not move.
I hope this helps and can lead me to what I am doing wrong.
Thank You
Don
27 May 2013 14:36 - 27 May 2013 14:39 #34745 by cncbasher
Replied by cncbasher on topic Running Linuxcnc
please post your hal and ini files as attachments . and also tell us what interface or controller you are using ?
are you using a Chinese tb6560 style controller , have you connected stepper enable to amplifier enable ?
do any error messages appear on screen
Last edit: 27 May 2013 14:39 by cncbasher.
27 May 2013 17:07 #34748 by Rick G
Replied by Rick G on topic Running Linuxcnc
This sounds like your acceleration and or velocity is set too high.
Are you sure the configuration you are using is the latest stepconfig created?
Are the motors here also making noise? When idle are they locked up?
Rick G
  • MakingToothpicks
  • Senior Member
  • Senior Member
28 May 2013 01:01 #34772 by MakingToothpicks
For Cncbasher here is the Hal and Ini files.
  • MakingToothpicks
  • Senior Member
  • Senior Member
28 May 2013 01:05 #34773 by MakingToothpicks
-If they work fine in stepconfig would they change using the program ?-
-This I will need to check. I will look at date created.-
-I will check further and see if the motors are locked or free to turn.-
Rick G[/quote]
  • MakingToothpicks
  • Senior Member
  • Senior Member
28 May 2013 02:01 #34780 by MakingToothpicks
Rick G
I just ran the machine again. When I load the NC file an error pops up.
RTAPI: ERROR: unexpected realtime delay on task 1
Run latency test again. I guess the test has me baffled.each time I run
the test I get different numbers. I keep changing them in the box and am
ok until the next time?
When I start the machine program the motors make noise and are locked up until I
hit the e-stop button.Then the motors stop making noise and are no longer locked up.
I load the NC file and get the error message.
When I run the latency test I get numbers at different times from lows of 2000 ns to
highs of 9900 ns.
The computer only runs Linuxcnc. No internet no other programs.
28 May 2013 02:58 #34787 by BigJohnT
Replied by BigJohnT on topic Running Linuxcnc
You need to run the latency test for a few hours then up the number by some margin. Remember you will only get the realtime delay error once per session even if you get billions of realtime delays.
JT
  • MakingToothpicks
  • Senior Member
  • Senior Member
28 May 2013 06:40 - 28 May 2013 06:44 #34803 by MakingToothpicks
Just ran Latency test for a couple of hours. Here are the numbers.
Max Interval
1046624
89652
Max Jitter
52744
64805
Last edit: 28 May 2013 06:44 by MakingToothpicks.
Time to create page: 0.070 seconds
