Running Linuxcnc
- MakingToothpicks
01 Jun 2013 03:03 #35059
by MakingToothpicks
Replied by MakingToothpicks on topic Running Linuxcnc
I am giving up on the China Blue controller board. Maybe I can get some input for what I should buy.
Money is tight . This is what I ma looking at Will this work for me
3 of these
probotix.com/stepper_motor_drivers/SideStep/
and 1 of these
probotix.com/breakout_boards/pbx-2/
There is this but I am not sure if it needs more parts or is it a complete breakout and driver
Also not sure I can assemble it. HobbyCNC PRO Chopper Driver Board Kit
I need to know it will work with Linuxcnc. I have become used to this software and the help.
There is also buildityouelcnc but they need 4 weeks lead time.
Thank You
3 of these
and 1 of these
Thank You
- BigJohnT
- Thank you received: 1175
01 Jun 2013 03:43 #35060
by BigJohnT
Replied by BigJohnT on topic Running Linuxcnc
If money is tight I would not give up on the TB6560 board, they are known to work usually unless you have blown it up. cncbasher is quite good with them.
You need to work through the problems in a logical order. Does it smell? If not get the drive to enable and go from there.
JT
JT
- Rick G
- Thank you received: 155
01 Jun 2013 17:04 #35084
by Rick G
Rick G
Replied by Rick G on topic Running Linuxcnc
As cncbasher pointed out this sounds like an enable problem, perhaps the enable signal needs to be inverted.I click the red button. the motors are making a noise
I hit the power button the motors stop making noise and the run pause and home buttons become active.]
Rick G
Time to create page: 0.049 seconds
