Running Linuxcnc
- Rick G
- Thank you received: 155
28 May 2013 14:19 - 28 May 2013 14:24 #34811
by Rick G
Replied by Rick G on topic Running Linuxcnc
You might want to start by looking here to improve your numbers...
wiki.linuxcnc.org/cgi-bin/wiki.pl?TroubleShooting
and the FAQ by Arceye here...
www.linuxcnc.org/index.php/english/forum/18-computer
Rick G
Rick G
Last edit: 28 May 2013 14:24 by Rick G.
- MakingToothpicks
29 May 2013 00:35 #34857
by MakingToothpicks
I read and used some of the suggestions at these links.
I now have Servo 7857 Base 5970
Latency test is still running and appears to be holding steady at these numbers.
Are these Ok or should I try for lower.
Thank You
Don
Replied by MakingToothpicks on topic Running Linuxcnc
Rick G
Thank You
Don
- BigJohnT
- Thank you received: 1176
29 May 2013 01:18 #34861
by BigJohnT
Replied by BigJohnT on topic Running Linuxcnc
Those are great numbers!
JT
JT
The following user(s) said Thank You: MakingToothpicks
- MakingToothpicks
29 May 2013 02:58 #34868
by MakingToothpicks
Well I used the new numbers and as soon as I start Linuxcnc I get the error.
No use in going any further. Nothing will work until this error is gone. I feel
I am out of options.
I don't know what to do now and am getting very tired. I am off to the Doctor
for some pains in my side and back. Been loosing a lot of sleep lately.
Of the 2 numbers what should or would you use and enter into stepconfig.
I am using the 5970 base as the number to enter into the box
- BigJohnT
29 May 2013 03:16 #34870
by BigJohnT
I would put 10,000 to start. You want to use a number higher than your highest jitter(latency).
JT
JT
- cncbasher
- Thank you received: 288
29 May 2013 13:58 #34895
by cncbasher
Replied by cncbasher on topic Running Linuxcnc
I would reduce these values until you get everything working too
MAX_ACCELERATION = 60.0
STEPGEN_MAXACCEL = 75.0
say 30 & 35
set your default velocity at 3
as JT says start with 10,000 as a latency figure
let us know how you get on , lets take one step at a time , the rtapi error has to be addressed first , as everything else depends on it
what is the spec of the motherboard your using , memory etc . is it a standard parrell port or are you using a addon card ?
say 30 & 35
- MakingToothpicks
29 May 2013 21:55 #34914
by MakingToothpicks
I used the 10,000 number and seem to have eliminated the error. I need to do some more
testing. I will get back to everyone when I can start Linuxcnc each time with no error.
Don
Don
- MakingToothpicks
30 May 2013 03:21 #34925
by MakingToothpicks
It appears to start now without errors. Now I need to find out why I have no movement.
For cncbasher the motherboard is an ECS model HT 2000 onboard video Geforce 6100.
coupe of gigs of ram. It was running Windows Home server until I installed Linuxcnc.
I will go over what is happening now :
I start CNC no errors. I load an NC file to test. I click the red button. the motors are making a noise
I hit the power button the motors stop making noise and the run pause and home buttons become active.
I home X,Y,Z and hit the run button. No movement out of the gantry. In the viewport window the icon for the
router head is moving and the program seems to be running.If I click the power button everything stops
and the run button and others become inactive but the Steppers power up ? I'm Lost ??
Thank You
PS maybe an enable pin needs to be reversed ??
Thank You
- cncbasher
30 May 2013 03:42 - 30 May 2013 03:48 #34928
by cncbasher
are you using amplifier enable ? check your enable is not reversed
the motors should be solid if you try to turn the shaft by hand once you press F2 on
are you using a Chinese tb6560 controller ?
if so which one .
if yes then the chance it is an enable problem
if so which one .
Last edit: 30 May 2013 03:48 by cncbasher.
- MakingToothpicks
30 May 2013 05:11 #34934
by MakingToothpicks
if so which one .
"Blue one."
"In Stepconfig there are 4 pins with enable checked. Pin 2 , 4 , 5 and 17 are enabled and checked. I think a check
mark in the box means reverse the action. I have tried a combination of check and not check each enable pin.It
seems like no matter what pin I check or unchecked an axis stops working. I would think 3 pins enabled would
correspond to 3 axis. then I am left with 1 pin. Not so if I uncheck the 4th pin 1 axis stops again.
I will keep pushing pins until something works. Mr.Spock s logic is not working LoL . I think I will need to revisit pinouts
for the board again."
Time to create page: 0.495 seconds
