Stepper vs. Servo Question for Turning Center
- Zahnrad Kopf
- Thank you received: 3
06 Jun 2013 07:09 #35310
by Zahnrad Kopf
I see! Well, I'm completely open to change, here. Yes, the steppers were 200 steps per rev, but if the result is BETTER resolution at some other PPR count, I'm open to it. They are not directly coupled at the moment, rather they are driven with belts and pulleys. And... buying pulleys is easy if a change is needed. But if push came to shove I can hob, WEDM, or mill anything I want for tooth counts or form.
Replied by Zahnrad Kopf on topic Stepper vs. Servo Question for Turning Center
The more the better, really. You won't be running the motors at 4000rpm, I wouldn't have thought.
The Mesa card can count encoders at Mhz.
Presumably the original steppers were 200 steps per rev, so you need some multiple of that to achieve the same resolution. (assuming direct coupling?)
- Zahnrad Kopf
06 Jun 2013 07:12 - 06 Jun 2013 07:12 #35311
by Zahnrad Kopf
It isn't, yet... I was planning on grabbing a 3HP 3Ø motor next week and coupling it with a VFD. But if there's a better idea I am all ears.
Threading definitely. Indexing is dependent on the motor more than the controller. What type of motor is it?
Last edit: 06 Jun 2013 07:12 by Zahnrad Kopf.
06 Jun 2013 18:01 #35323
by BigJohnT
Something doesn't look right with a 3hp spindle motor and nema 23 steppers for the axes. What was the original spindle motor size?
JT
Replied by BigJohnT on topic Stepper vs. Servo Question for Turning Center
JT
06 Jun 2013 18:11 #35325
My lathe is 2Hp and NEMA23 steppers and I can stall the spindle all too easily.
Replied by andypugh on topic Stepper vs. Servo Question for Turning Center
06 Jun 2013 18:15 #35327
You want at least 1000ppr *(4000cpr) encoders, I would think.
You might want to consider increasing the gear ratio. Steppers tend to max out at a few hundred rpm, whereas servos can do a few thousand. But try it first with the original gearing, see how it works out.I see! Well, I'm completely open to change, here. Yes, the steppers were 200 steps per rev, but if the result is BETTER resolution at some other PPR count, I'm open to it. They are not directly coupled at the moment, rather they are driven with belts and pulleys. And... buying pulleys is easy if a change is needed. But if push came to shove I can hob, WEDM, or mill anything I want for tooth counts or form.
06 Jun 2013 18:18 #35328
by BigJohnT
I guess that depends on the gear ratio and such... I was using my mill as a guide which has a 1 1/2hp spindle and huge DC brushed servos and I can spin a 3" face mill with it. I guess that is not a fair comparison to a lathe somehow?
I get the idea somehow that this is a table top lathe...
JT
JT
- Zahnrad Kopf
06 Jun 2013 18:21 #35329
by Zahnrad Kopf
John,
It is a 5HP 380VDC motor. Emco REALLY over built these. I figured I could get away with a 3HP motor since the machine is so compact. I have ZERO issue with going with a 5HP motor though.
Something doesn't look right with a 3hp spindle motor and nema 23 steppers for the axes. What was the original spindle motor size? JT
John,
- Zahnrad Kopf
06 Jun 2013 18:25 #35331
by Zahnrad Kopf
John,
They are not quite table top, but not quite full size. They are compact, but full-on turning centers, very capable, and deadly accurate. ( very rigid ) Hence, my desire to keep it and retrofit it. Lemme see if this works...
JT
John,
- Zahnrad Kopf
06 Jun 2013 18:27 #35332
by Zahnrad Kopf
Thanks, Andy. I will plan for that.
You might want to consider increasing the gear ratio. Steppers tend to max out at a few hundred rpm, whereas servos can do a few thousand. But try it first with the original gearing, see how it works out. You want at least 1000ppr *(4000cpr) encoders, I would think.
06 Jun 2013 18:30 #35333
by BigJohnT
That's bigger than I imaged for nema 23, but what the heck do I know. The control panel is almost as big as the lathe!
JT
JT
Time to create page: 0.137 seconds
