Stepper vs. Servo Question for Turning Center
- Zahnrad Kopf
- Thank you received: 3
06 Jun 2013 18:33 - 06 Jun 2013 18:37 #35334
by Zahnrad Kopf
I know... That's just ANOTHER of the upsides of getting rid of that thing...
The steppers are Berger Lahr RDM 596/50 5 phase steppers. Approximately 110 oz/in.
EDIT - I should point out that EVERYTHING is contained in that cabinet. There is an elaborate frequency drive for the spindle motor that consists of 5 or 6 different cards/boards, plus stepper drives, plus controller cards/boards, etc... it's a mess. It's very Austrian...
Replied by Zahnrad Kopf on topic Stepper vs. Servo Question for Turning Center
That's bigger than I imaged for nema 23, but what the heck do I know. The control panel is almost as big as the lathe! JT
Last edit: 06 Jun 2013 18:37 by Zahnrad Kopf.
06 Jun 2013 18:46 #35335
by BigJohnT
Replied by BigJohnT on topic Stepper vs. Servo Question for Turning Center
- Zahnrad Kopf
06 Jun 2013 18:53 #35336
by Zahnrad Kopf
Yes, that is its predecessor. The Compact6 lead to the 120 and then 220, some ( like my own ) with a P for pneumatic control of things like chuck, tail, parts catcher... Same basic frame, different spindle and accessory options. Many had bar feeders. My own did at some point. They are seriously over built machines, inside.
- Zahnrad Kopf
06 Jun 2013 20:26 #35341
by Zahnrad Kopf
So what kind of motor were you guys thinking of in regard to spindle positioning? ( C axis )
06 Jun 2013 21:53 #35346
I am not sure how well positioning works with an induction motor + VFD. I believe it is OK for toolchanger alignment, but I don't know if it would be stiff enough for C -axis work.
You definitely need a flux-vector drive, my own experiments with a traditional v/f VFD were less than a huge success.
For proper rotary-axis use you probably need a servo, and a big one too. Though I am planning to experiment with a washing machine motor.
Replied by andypugh on topic Stepper vs. Servo Question for Turning Center
- Zahnrad Kopf
06 Jun 2013 22:04 #35347
by Zahnrad Kopf
Thanks, Andy. If I'm asking too much of it right now, it is likely best not to go so heavily into the modifying side right out of the gate, and just get the thing running, for now. I can always experiment later. I will have to view that video later. Thank you.
- Zahnrad Kopf
07 Jun 2013 00:33 #35353
by Zahnrad Kopf
Another question here regarding the whole servo conversion and Mesa cards.
That tool changer that uses the 24VDC motor... does that have any effect on the choice of 5i25/7i77 combo? Will controlling it be done from those, or will I require other hardware? Hopefully someone will know off hand, and Peter will chime in as well.
07 Jun 2013 00:50 #35354
by BigJohnT
You can use the outputs on the 7i77 to pull in a relay to run your tool changer motor and pneumatic valves.
JT
JT
- Zahnrad Kopf
07 Jun 2013 00:58 - 07 Jun 2013 00:58 #35355
by Zahnrad Kopf
Thanks, John. I have to admit that I am kind of worried... It just feels like I am "missing" or overlooking something big, here....
PC
Servo motors
Servo drives
Servo encoders
Spindle motor
Spindle motor VFD
Mesa 5i25 and 7i77
Power supply transformers and such
Various control panel bits ( MPG, buttons, monitor )
Wire it all together.
I know I will eat these words later, but it just seems too easy at the moment. Hence my thinking that I am missing something important.
PC
Servo motors
Servo drives
Servo encoders
Spindle motor
Spindle motor VFD
Mesa 5i25 and 7i77
Last edit: 07 Jun 2013 00:58 by Zahnrad Kopf.
07 Jun 2013 01:38 #35360
by BigJohnT
Well I don't see a 24vdc field power transformer on your list but they are cheap compared to the rest of your list.
JT
JT
Time to create page: 0.082 seconds
