Help with my "Linxcnc for Dummies" web page.
- Thank you received: 5291
06 May 2014 21:53 - 06 May 2014 21:53 #46656
Replied by PCW on topic Help with my "Linxcnc for Dummies" web page.
Looks like it supports +-10V input for bi-directional control so as a first shot:
STF --> 7I77 ENA5+ (22)
SD --> 7I77 ENA5- (21)
1 --> 7I77 AOUT5 (24)
5 --> 7I77 GND (23)
PR 73 must be set to '1' for bi-directional operation
Be aware that VFDs are notoriously noisy so you may need a common mode choke
on the AOUT5/7I77GND leads to the VFD
A common mode choke for this application is basically a large ferrite bead
with the 7I77 AOUT5 and GND pair fed through the middle
5 --> 7I77 GND (23)
Last edit: 06 May 2014 21:53 by PCW.
The following user(s) said Thank You: greeder88
- greeder88
07 May 2014 00:45 #46657
by greeder88
Replied by greeder88 on topic Help with my "Linxcnc for Dummies" web page.
I have it wired now however the hal configuration is an issue.
I took a wild stab at it based on a regular axis.
Probably doesn't use pid.
I doubt I am even close.
net vfd-enable pid.5.enable <= axis.5.amp-enable-out
net vfd-command pid.5.output => hm2_5i25.0.7i77.0.1.analogout5
07 May 2014 01:22 #46658
linuxcnc.org/docs/html/examples/spindle.html
has some examples
Since you are not going to be using a PID loop to control the spindle speed it should be pretty basic:
net vfd-enable motion.spindle-on <= axis.5.amp-enable-out
net vfd-command motion.spindle-speed-out => hm2_5i25.0.7i77.0.1.analogout5
You will also need to scale the analog output to match your spindle top speed at +-10V:
setp hm2_5i25.0.7i77.0.1.analogout5-scalemax 5000
setp hm2_5i25.0.7i77.0.1.analogout5-maxlim 5000
setp hm2_5i25.0.7i77.0.1.analogout5-minlim -5000
Assuming 5000 RPM is the spindle speed with a 10V
command and you want the spindle to be reversible.
has some examples
- greeder88
07 May 2014 03:39 #46661
by greeder88
Ran into that "pin does not exist" error again.
it was on:
Is there something needed in the INI file for axis 5?
it was on:
07 May 2014 04:09 #46663
sorry that should be
net vfd-enable motion.spindle-on => hm2_5i25.0.7i77.0.1.spinena
BTW when linuxcnc is up and running
I would do a:
in a terminal window so you can know what
hal pins and parameters are available
I would do a:
halcmd show all > allhal.txt
- greeder88
07 May 2014 04:43 #46664
by greeder88
Axis is back up and running.
Unfortunately the VFD is still looking for the encoder.
The part of the instructions for changing to V/F control says:
Short circuit across terminals MC and SD ...the operation will change to "V/F control"
I can't find a MC terminal anywhere and assumed it was the 3 digital terminals but since it is not switched over
probably not. This is the only thing left that I haven't done.
Not sure what they mean by "Short Circuit". Sounds bad.
Can't find MC.
Can't find MC.
- greeder88
07 May 2014 05:12 - 07 May 2014 05:33 #46666
by greeder88
Found MC terminal.
It is DI1, DI2,DI3.
Now the tricky part:
Says "Speed, torque, or V/F control can be selected with this parameter (Pr. 14)
and switched between with the MC terminal (DI1, DI2, DI3).
Do you think I have to short circuit one of these pins with a wire to "SD"?
Sounds like it to me but "Short Circuit" is not something I want to do without checking.
It is DI1, DI2,DI3.
Last edit: 07 May 2014 05:33 by greeder88.
07 May 2014 10:44 #46672
All the digital inputs are actuated by being connected to SD so this is normal
Looks like pr99 is involved in this also
- greeder88
07 May 2014 16:08 #46676
by greeder88
This is harder to get the VFD working without the encoder than putting one on.
If someone can attach a working hal section for a VFD with encoder I will just wire up the encoder today and hopefully be finished.
I've been working on my web site and need working hal sections for both encoder and non encoder VFD spindles anyway.
I'm pretty much limited to cut and paste hal file construction. I have to raise the white flag and surrender on learning hal.
- greeder88
09 May 2014 01:17 #46731
by greeder88
I have the VFD with encoder hooked up and the errors went away. Reading 0. I assume 0 rpm.
Worried my VFD was bad but looking good.
I still need (Soon or Eventually) a good VFD with encoder HAL to copy. If someone can post a link to one that might do the trick.
Looked at the manual pages and the VFD section is complicated beyond belief. I definitely need to copy one.
Time to create page: 0.081 seconds
