Advice on component selection.
- NeoTech
07 Jan 2015 04:31 #54687
by NeoTech
Replied by NeoTech on topic Advice on component selection.
Ah cool now i know how to read that thing at least.
And yeah, then i have alot of crap i need to strip out of this installation .=)
Im still experimenting with GUI's and modifying the installation.
- Thank you received: 4967
07 Jan 2015 04:39 #54688
Replied by andypugh on topic Advice on component selection.
Try cd /usr/realtime-2.6.32-122-rtai/testsuite/kern/latency/ then ./run and see if there is a periodicity to the high latency values. If it happens at regular (64 seconds, for example) intervals then suspect SMI.
- Thank you received: 5216
07 Jan 2015 04:39 #54689
Replied by PCW on topic Advice on component selection.
First thing to do to improve latency is turn off _all_ power management/ and speed switching options in the BIOS
Then if your CPU supports hyperthreading, turn it off also
- NeoTech
07 Jan 2015 04:49 #54690
by NeoTech
Ah well dont know if that test suit exists on my build.. i used Wheezy in the bottom, installed a realtime kernen from repository then compiled from source.. so for some reason i got 2.8.x something, maybe could be an issue i guess?
Power management is always off - i deactivate all that crap in every puter i own on bios level.. =)
But, why should i turn off hyperthreading, guessing that would help out with calculations - not that a Core i5 processor support hyperthreading, but have 4 cores at least.
07 Jan 2015 04:51 #54691
Probably not, but you ought to have the equivalent for your kernel.
- NeoTech
07 Jan 2015 04:57 #54692
by NeoTech
I shall investigate. =)
07 Jan 2015 05:39 #54695
Not sure why but hyperthreading is a known latency poison, its _always_ better when off
I guess only 2 core I5s have hyperthreading
- NeoTech
07 Jan 2015 05:41 #54697
by NeoTech
Ah right, you are talking about the mobile processors like Core i5m - those that use hyperthreading to emulate 4 cores, and are marketed as 4 cores.
- NeoTech
08 Jan 2015 08:13 #54734
by NeoTech
08 Jan 2015 08:27 #54736
In my experience running flash videos on youtube is about the worst RT torture test
