6x6 Stewart (Parallel Kinematic Machine Tool)
  • ommar
  • ommar's Avatar Topic Author
  • Junior Member
  • Junior Member
05 Apr 2016 06:36 #72768 by ommar
egmak@debian:~$ sudo su
[sudo] password for egmak:
root@debian:/home/egmak# halrun
halcmd: loadrt genhexkins
halcmd: show param
Parameters:
Owner   Type  Dir         Value  Name
halcmd:
Parameters did not list. What must i do ?
05 Apr 2016 09:03 #72770 by andypugh
Replied by andypugh on topic 6x6 Stewart (Parallel Kinematic Machine Tool)
You shouldn't need sudo.
I am confused about why there is no error, but no pins.
As I suggested, try "show all"
05 Apr 2016 12:11 #72778 by jepler
2.6 does not have the parameters, 2.7 does. andypugh may have made a mistake in his earlier message which seemed to show parameters while running with 2.6.
yes, "sudo" / "su" should be unnecessary to run linuxcnc or halrun. When building linuxcnc for yourself, the only step done with "sudo" is "sudo make setuid".
  • ommar
  • Junior Member
  • Junior Member
01 May 2016 15:04 #74105 by ommar
Hi everybody,
I builded my hexapod. Nowadays i try to control one step motor. I connected the step motor driver and mesa 7i76 daughter card and 6i25 card. I used to pncconfig wizard but i did not move the step motor. Software giving an error like this;
And this is the ini file;
# Generated by PNCconf at Sun May  1 15:21:22 2016
# overwritten when you run PNCconf again
[EMC]
MACHINE = my_LinuxCNC_machine_deneme
DEBUG = 0
[DISPLAY]
DISPLAY = axis
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2.000000
MAX_SPINDLE_OVERRIDE = 1.000000
MIN_SPINDLE_OVERRIDE = 0.500000
INTRO_TIME = 5
PROGRAM_PREFIX = /home/egmach/linuxcnc/nc_files
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
DEFAULT_LINEAR_VELOCITY = 0.250000
MAX_LINEAR_VELOCITY = 1.000000
MIN_LINEAR_VELOCITY = 0.010000
DEFAULT_ANGULAR_VELOCITY = 0.250000
MAX_ANGULAR_VELOCITY = 1.000000
MIN_ANGULAR_VELOCITY = 0.010000
EDITOR = gedit
GEOMETRY = xyz
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
SERVO_PERIOD = 1000000
[HOSTMOT2]
# **** This is for info only ****
# DRIVER0=hm2_pci
# BOARD0=5i25
[HAL]
HALUI = halui
HALFILE = my_LinuxCNC_machine_deneme.hal
HALFILE = custom.hal
POSTGUI_HALFILE = postgui_call_list.hal
SHUTDOWN = shutdown.hal
[HALUI]
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 2.50
MAX_LINEAR_VELOCITY = 25.00
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
# Axis X
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 25.0
MAX_ACCELERATION = 750.0
STEPGEN_MAXVEL = 31.25
STEPGEN_MAXACCEL = 937.50
P = 50.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
# these are in nanoseconds
DIRSETUP   = 10000
DIRHOLD    = 10000
STEPLEN    = 10000
STEPSPACE  = 10000
STEP_SCALE = 400000.0
MIN_LIMIT = -0.01
MAX_LIMIT = 2000000.0
HOME_OFFSET = 0.0
# Axis Y
[AXIS_1]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 25.0
P = 50.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP   = 2000
DIRHOLD    = 2000
STEPLEN    = 2000
STEPSPACE  = 2000
MIN_LIMIT = -0.01
HOME_OFFSET = 0.0
# Axis Z
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 25.0
P = 50.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP   = 2000
DIRHOLD    = 2000
STEPLEN    = 2000
STEPSPACE  = 2000
MIN_LIMIT = -1000000.0
MAX_LIMIT = 0.01
HOME_OFFSET = 0.0
# Spindle
[SPINDLE_9]
P = 0
I = 0
D = 0
FF0 = 1
FF1 = 0
FF2 = 0
BIAS = 0
DEADBAND = 0
MAX_OUTPUT = 2000
Can you help me ?
Thank you.
01 May 2016 16:10 #74107 by andypugh
Where did you get those numbers from?
400,000 steps per mm is unlikely to be correct.
  • ommar
  • Junior Member
  • Junior Member
01 May 2016 16:57 #74108 by ommar
Pncconfig wizard give this number. Is this uncorrect ? or is this number source of error ?
01 May 2016 19:03 #74112 by andypugh
I suspect that your input values to pncconf might be in error.
What do you get if you calculate steps-per-mm by hand?
  • ommar
  • Junior Member
  • Junior Member
31 May 2016 11:49 #75281 by ommar
I editted the kinematics.hal (configs/sim/axis/vismach/hexapod-sim/hexapod) file for my machine coordinates. And i started linuxcnc but 3D model is not update for my joint coordinates. In addition i can not find genhexkins and trivkins files. Are these files stay in configs/sim/axis/vismach/hexapod-sim/hexapod directory ? Must i install these files ? I am confused. Can you help me ?
31 May 2016 12:14 #75282 by andypugh
Did you edit the files in your ~/linuxcnc/configs directory or some others?
The kinematics files normally live in /usr/bin I think. If the congif starts then LinuxCNC is able to find the files.
which genhexkins
might help to find the files that are being used.
  • ommar
  • Junior Member
  • Junior Member
31 May 2016 13:04 - 31 May 2016 13:04 #75286 by ommar
which genhexkins
Yes i editted ~/linuxcnc/configs directory. The command is not working.
Last edit: 31 May 2016 13:04 by ommar.
Time to create page: 0.321 seconds
