6x6 Stewart (Parallel Kinematic Machine Tool)
31 May 2016 13:06 #75287 by andypugh
Replied by andypugh on topic 6x6 Stewart (Parallel Kinematic Machine Tool)
You could try the more long-winded:
sudo find / -name genhexkins.ko
  • ommar
  • ommar's Avatar Topic Author
  • Junior Member
  • Junior Member
03 Jun 2016 12:31 #75404 by ommar
I defined my hexapod joints coordinates in the kinematics.ini file. (linuxcnc/configs/sim.axis.vismach.hexapod-sim/)
Will i edit additionally files ? Is it enough for the kinematic calculation ?
On the other hand;
I tested all of the motors in pncconfig successfully. I can move them. I have one 6i25 and two 7i76 mesa cards.
I am planning that;
I will define X,Y,Z axis in Pncconfig for one mesa 7i76 card and
i will define A,B,C axis for the other mesa 7i76card.
Pnconfig will create two ini file.
Will i copy these ini files into linuxcnc/configs/sim.axis.vismach.hexapod-sim/hexapd.ini ?
Thank you.
03 Jun 2016 12:50 #75410 by andypugh
You will have one INI file and one config. LinuxCNC handles up to 9 joints, and does not really care what hardware they are connected to.
To save confusion, it is probably better to talk about joints 0, 1, 2,..5 for each leg of the hexapod. The axes XYZABC define the position in space and the orientation of the platform, not the leg lengths.
  • ommar
  • Junior Member
  • Junior Member
03 Jun 2016 13:01 - 03 Jun 2016 13:11 #75416 by ommar
You are right. I am confused.
I will not use pncconfig in that case. I will only edit hexapod.ini. Am i true ?
May you explain step by step.
Last edit: 03 Jun 2016 13:11 by ommar.
03 Jun 2016 13:10 #75418 by andypugh
A config is both an INI and a HAL file. The demo hexapod config does not (as far as I know) use a Mesa card.
Setting up as an XYZABC config in pncconf will probably get you close, but then you will need to edit the hal and ini to suit a genhexkins configuration.
I would set the machine up as XYZABC first, and get the motors all responding in the right way to G-code moves in those directions with the motors _not_ connected to the platform.
Then, and only then, change the machine to genhexkins and make sure that the motors still move in the right sort of way. Then, and only then, you can connect the motors to the frame.
I have slightly lost track, are you using 2.7.4 or Joints_Axes14?
  • ommar
  • Junior Member
  • Junior Member
03 Jun 2016 13:16 #75419 by ommar
I am using 2.7.4. My hexapod has got six motors. 6 axes.
03 Jun 2016 13:22 #75421 by andypugh
In that case you should probably start with pncconf to get all the motors moving, and them look at the hexapos sample files to see how a hexapod configuration is different from a trivkins configuration.
Note that the number of Axes and the number of motors are not necessarily the same.
  • ommar
  • Junior Member
  • Junior Member
03 Jun 2016 13:30 #75423 by ommar
I can move the motors in the pncconfig. But Pncconfig allows maximum 4 axes (XYZA). Whats is trivkins ? I don't know.
03 Jun 2016 13:32 #75424 by andypugh
OK, so you have slightly more to do, but it is mainly just a copy-and-paste exercise in the HAL and INI files.
linuxcnc.org/docs/2.7/html/motion/kinematics.html
  • ommar
  • Junior Member
  • Junior Member
06 Jun 2016 07:59 - 06 Jun 2016 10:35 #75544 by ommar
Can you analyze my pncconfig settings ?
Here are the windows;
1. Base information
Are the settings suitable in the I/O Control Ports / Boards ? (6i25+7i76+7i76)
2. Mesa Card
Are the selections of the board name and firmware true for my combination ?
3. I/O Connector 2
I think that I/O connector 2 is part of one of 7i76 card. Is it true ? I defined 3 motor in this page.
4. I/O Connector 3
I think that I/O connector 2 is part of the another 7i76 card. Is it true ? I defined other 3 motors in this page but i can only test the perivous 3 motors.
5. X Motor
Here are the stepper parameters. I can move the motor.
I can move the y and z motors like these. Pncconfig created hal and ini file. Here are the files.
HAL File;
# Generated by PNCconf at Mon Jun  6 10:24:33 2016
# overwritten when you run PNCconf again
loadrt trivkins
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt hostmot2
loadrt hm2_pci config=" num_encoders=2 num_pwmgens=0 num_stepgens=10 sserial_port_0=0000xx"
setp    hm2_5i25.0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.y,pid.z,pid.s
addf hm2_5i25.0.read          servo-thread
addf motion-command-handler   servo-thread
addf motion-controller        servo-thread
addf pid.x.do-pid-calcs       servo-thread
addf pid.y.do-pid-calcs       servo-thread
addf pid.z.do-pid-calcs       servo-thread
addf pid.s.do-pid-calcs       servo-thread
addf hm2_5i25.0.write         servo-thread
# external output signals
# external input signals
#  AXIS X
setp   pid.x.Pgain     [AXIS_0]P
setp   pid.x.Igain     [AXIS_0]I
setp   pid.x.Dgain     [AXIS_0]D
setp   pid.x.bias      [AXIS_0]BIAS
setp   pid.x.FF0       [AXIS_0]FF0
setp   pid.x.FF1       [AXIS_0]FF1
setp   pid.x.FF2       [AXIS_0]FF2
setp   pid.x.deadband  [AXIS_0]DEADBAND
setp   pid.x.maxoutput [AXIS_0]MAX_OUTPUT
setp   pid.x.error-previous-target true
setp   pid.x.maxerror .0005
net x-index-enable  <=> pid.x.index-enable
net x-enable        =>  pid.x.enable
net x-pos-cmd       =>  pid.x.command
net x-vel-cmd       =>  pid.x.command-deriv
net x-pos-fb        =>  pid.x.feedback
net x-output        =>  pid.x.output
# Step Gen signals/setup
setp   hm2_5i25.0.stepgen.05.dirsetup        [AXIS_0]DIRSETUP
setp   hm2_5i25.0.stepgen.05.dirhold         [AXIS_0]DIRHOLD
setp   hm2_5i25.0.stepgen.05.steplen         [AXIS_0]STEPLEN
setp   hm2_5i25.0.stepgen.05.stepspace       [AXIS_0]STEPSPACE
setp   hm2_5i25.0.stepgen.05.position-scale  [AXIS_0]STEP_SCALE
setp   hm2_5i25.0.stepgen.05.step_type        0
setp   hm2_5i25.0.stepgen.05.control-type     1
setp   hm2_5i25.0.stepgen.05.maxaccel         [AXIS_0]STEPGEN_MAXACCEL
setp   hm2_5i25.0.stepgen.05.maxvel           [AXIS_0]STEPGEN_MAXVEL
# ---closedloop stepper signals---
net x-pos-cmd    <= axis.0.motor-pos-cmd
net x-vel-cmd    <= axis.0.joint-vel-cmd
net x-output     <= hm2_5i25.0.stepgen.05.velocity-cmd
net x-pos-fb     <= hm2_5i25.0.stepgen.05.position-fb
net x-pos-fb     => axis.0.motor-pos-fb
net x-enable     <= axis.0.amp-enable-out
net x-enable     => hm2_5i25.0.stepgen.05.enable
# ---setup home / limit switch signals---
net x-home-sw     =>  axis.0.home-sw-in
net x-neg-limit     =>  axis.0.neg-lim-sw-in
net x-pos-limit     =>  axis.0.pos-lim-sw-in
#  AXIS Y
setp   pid.y.Pgain     [AXIS_1]P
setp   pid.y.Igain     [AXIS_1]I
setp   pid.y.Dgain     [AXIS_1]D
setp   pid.y.bias      [AXIS_1]BIAS
setp   pid.y.FF0       [AXIS_1]FF0
setp   pid.y.FF1       [AXIS_1]FF1
setp   pid.y.FF2       [AXIS_1]FF2
setp   pid.y.deadband  [AXIS_1]DEADBAND
setp   pid.y.maxoutput [AXIS_1]MAX_OUTPUT
setp   pid.y.error-previous-target true
setp   pid.y.maxerror .0005
net y-index-enable  <=> pid.y.index-enable
net y-enable        =>  pid.y.enable
net y-pos-cmd       =>  pid.y.command
net y-vel-cmd       =>  pid.y.command-deriv
net y-pos-fb        =>  pid.y.feedback
net y-output        =>  pid.y.output
setp   hm2_5i25.0.stepgen.06.dirsetup        [AXIS_1]DIRSETUP
setp   hm2_5i25.0.stepgen.06.dirhold         [AXIS_1]DIRHOLD
setp   hm2_5i25.0.stepgen.06.steplen         [AXIS_1]STEPLEN
setp   hm2_5i25.0.stepgen.06.stepspace       [AXIS_1]STEPSPACE
setp   hm2_5i25.0.stepgen.06.position-scale  [AXIS_1]STEP_SCALE
setp   hm2_5i25.0.stepgen.06.step_type        0
setp   hm2_5i25.0.stepgen.06.control-type     1
setp   hm2_5i25.0.stepgen.06.maxaccel         [AXIS_1]STEPGEN_MAXACCEL
setp   hm2_5i25.0.stepgen.06.maxvel           [AXIS_1]STEPGEN_MAXVEL
net y-pos-cmd    <= axis.1.motor-pos-cmd
net y-vel-cmd    <= axis.1.joint-vel-cmd
net y-output     <= hm2_5i25.0.stepgen.06.velocity-cmd
net y-pos-fb     <= hm2_5i25.0.stepgen.06.position-fb
net y-pos-fb     => axis.1.motor-pos-fb
net y-enable     <= axis.1.amp-enable-out
net y-enable     => hm2_5i25.0.stepgen.06.enable
net y-home-sw     =>  axis.1.home-sw-in
net y-neg-limit     =>  axis.1.neg-lim-sw-in
net y-pos-limit     =>  axis.1.pos-lim-sw-in
#  AXIS Z
setp   pid.z.Pgain     [AXIS_2]P
setp   pid.z.Igain     [AXIS_2]I
setp   pid.z.Dgain     [AXIS_2]D
setp   pid.z.bias      [AXIS_2]BIAS
setp   pid.z.FF0       [AXIS_2]FF0
setp   pid.z.FF1       [AXIS_2]FF1
setp   pid.z.FF2       [AXIS_2]FF2
setp   pid.z.deadband  [AXIS_2]DEADBAND
setp   pid.z.maxoutput [AXIS_2]MAX_OUTPUT
setp   pid.z.error-previous-target true
setp   pid.z.maxerror .0005
net z-index-enable  <=> pid.z.index-enable
net z-enable        =>  pid.z.enable
net z-pos-cmd       =>  pid.z.command
net z-vel-cmd       =>  pid.z.command-deriv
net z-pos-fb        =>  pid.z.feedback
net z-output        =>  pid.z.output
setp   hm2_5i25.0.stepgen.07.dirsetup        [AXIS_2]DIRSETUP
setp   hm2_5i25.0.stepgen.07.dirhold         [AXIS_2]DIRHOLD
setp   hm2_5i25.0.stepgen.07.steplen         [AXIS_2]STEPLEN
setp   hm2_5i25.0.stepgen.07.stepspace       [AXIS_2]STEPSPACE
setp   hm2_5i25.0.stepgen.07.position-scale  [AXIS_2]STEP_SCALE
setp   hm2_5i25.0.stepgen.07.step_type        0
setp   hm2_5i25.0.stepgen.07.control-type     1
setp   hm2_5i25.0.stepgen.07.maxaccel         [AXIS_2]STEPGEN_MAXACCEL
setp   hm2_5i25.0.stepgen.07.maxvel           [AXIS_2]STEPGEN_MAXVEL
net z-pos-cmd    <= axis.2.motor-pos-cmd
net z-vel-cmd    <= axis.2.joint-vel-cmd
net z-output     <= hm2_5i25.0.stepgen.07.velocity-cmd
net z-pos-fb     <= hm2_5i25.0.stepgen.07.position-fb
net z-pos-fb     => axis.2.motor-pos-fb
net z-enable     <= axis.2.amp-enable-out
net z-enable     => hm2_5i25.0.stepgen.07.enable
net z-home-sw     =>  axis.2.home-sw-in
net z-neg-limit     =>  axis.2.neg-lim-sw-in
net z-pos-limit     =>  axis.2.pos-lim-sw-in
#  SPINDLE S
setp   pid.s.Pgain     [SPINDLE_9]P
setp   pid.s.Igain     [SPINDLE_9]I
setp   pid.s.Dgain     [SPINDLE_9]D
setp   pid.s.bias      [SPINDLE_9]BIAS
setp   pid.s.FF0       [SPINDLE_9]FF0
setp   pid.s.FF1       [SPINDLE_9]FF1
setp   pid.s.FF2       [SPINDLE_9]FF2
setp   pid.s.deadband  [SPINDLE_9]DEADBAND
setp   pid.s.maxoutput [SPINDLE_9]MAX_OUTPUT
setp   pid.s.error-previous-target true
net spindle-index-enable  <=> pid.s.index-enable
net spindle-enable        =>  pid.s.enable
net spindle-vel-cmd-rpm     => pid.s.command
net spindle-vel-fb-rpm      => pid.s.feedback
net spindle-output        <=  pid.s.output
net spindle-vel-cmd-rps        <=  motion.spindle-speed-out-rps
net spindle-vel-cmd-rps-abs    <=  motion.spindle-speed-out-rps-abs
net spindle-vel-cmd-rpm        <=  motion.spindle-speed-out
net spindle-vel-cmd-rpm-abs    <=  motion.spindle-speed-out-abs
net spindle-enable             <=  motion.spindle-on
net spindle-cw                 <=  motion.spindle-forward
net spindle-ccw                <=  motion.spindle-reverse
net spindle-brake              <=  motion.spindle-brake
net spindle-revs               =>  motion.spindle-revs
net spindle-at-speed           =>  motion.spindle-at-speed
net spindle-vel-fb-rps         =>  motion.spindle-speed-in
net spindle-index-enable      <=>  motion.spindle-index-enable
sets spindle-at-speed true
# connect miscellaneous signals
#  ---HALUI signals---
net joint-select-a        halui.joint.0.select
net x-is-homed            halui.joint.0.is-homed
net jog-x-pos             halui.jog.0.plus
net jog-x-neg             halui.jog.0.minus
net jog-x-analog          halui.jog.0.analog
net joint-select-b        halui.joint.1.select
net y-is-homed            halui.joint.1.is-homed
net jog-y-pos             halui.jog.1.plus
net jog-y-neg             halui.jog.1.minus
net jog-y-analog          halui.jog.1.analog
net joint-select-c        halui.joint.2.select
net z-is-homed            halui.joint.2.is-homed
net jog-z-pos             halui.jog.2.plus
net jog-z-neg             halui.jog.2.minus
net jog-z-analog          halui.jog.2.analog
net jog-selected-pos      halui.jog.selected.plus
net jog-selected-neg      halui.jog.selected.minus
net spindle-manual-cw     halui.spindle.forward
net spindle-manual-ccw    halui.spindle.reverse
net spindle-manual-stop   halui.spindle.stop
net machine-is-on         halui.machine.is-on
net jog-speed             halui.jog-speed
net MDI-mode              halui.mode.is-mdi
#  ---coolant signals---
net coolant-mist      <=  iocontrol.0.coolant-mist
net coolant-flood     <=  iocontrol.0.coolant-flood
#  ---probe signal---
net probe-in     =>  motion.probe-input
#  ---motion control signals---
net in-position               <=  motion.in-position
net machine-is-enabled        <=  motion.motion-enabled
#  ---digital in / out signals---
#  ---estop signals---
net estop-out     <=  iocontrol.0.user-enable-out
net estop-out     =>  iocontrol.0.emc-enable-in
#  ---manual tool change signals---
net tool-change-request     iocontrol.0.tool-change       =>  hal_manualtoolchange.change
net tool-change-confirmed   iocontrol.0.tool-changed      <=  hal_manualtoolchange.changed
net tool-number             iocontrol.0.tool-prep-number  =>  hal_manualtoolchange.number
net tool-prepare-loopback   iocontrol.0.tool-prepare      =>  iocontrol.0.tool-prepared
INI file
[EMC]
MACHINE = DENEME_6Haz_10:19
DEBUG = 0
[DISPLAY]
DISPLAY = axis
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2.000000
MAX_SPINDLE_OVERRIDE = 1.000000
MIN_SPINDLE_OVERRIDE = 0.500000
INTRO_TIME = 5
PROGRAM_PREFIX = /home/egmach/linuxcnc/nc_files
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
DEFAULT_LINEAR_VELOCITY = 0.250000
MAX_LINEAR_VELOCITY = 1.000000
MIN_LINEAR_VELOCITY = 0.010000
DEFAULT_ANGULAR_VELOCITY = 0.250000
MAX_ANGULAR_VELOCITY = 1.000000
MIN_ANGULAR_VELOCITY = 0.010000
EDITOR = gedit
GEOMETRY = xyz
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
SERVO_PERIOD = 1000000
[HOSTMOT2]
# **** This is for info only ****
# DRIVER0=hm2_pci
# BOARD0=5i25
[HAL]
HALUI = halui
HALFILE = DENEME_6Haz_10:19.hal
HALFILE = custom.hal
POSTGUI_HALFILE = postgui_call_list.hal
SHUTDOWN = shutdown.hal
[HALUI]
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 0.33
MAX_LINEAR_VELOCITY = 3.33
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
# Axis X
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 3.33333333333
MAX_ACCELERATION = 5.0
STEPGEN_MAXVEL = 4.17
STEPGEN_MAXACCEL = 6.25
P = 50.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
# these are in nanoseconds
DIRSETUP   = 1000
DIRHOLD    = 1000
STEPLEN    = 1000
STEPSPACE  = 1000
STEP_SCALE = 1280.0
MIN_LIMIT = -0.01
MAX_LIMIT = 200.0
HOME_OFFSET = 0.0
# Axis Y
[AXIS_1]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
P = 50.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP   = 1000
DIRHOLD    = 1000
STEPLEN    = 1000
STEPSPACE  = 1000
STEP_SCALE = 1280.0
MIN_LIMIT = -0.01
MAX_LIMIT = 200.0
HOME_OFFSET = 0.0
# Axis Z
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
P = 50.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP   = 1000
DIRHOLD    = 1000
STEPLEN    = 1000
STEPSPACE  = 1000
STEP_SCALE = 1280.0
MIN_LIMIT = -100.0
MAX_LIMIT = 0.01
HOME_OFFSET = 0.0
# Spindle
[SPINDLE_9]
P = 0
I = 0
D = 0
FF0 = 1
FF1 = 0
FF2 = 0
BIAS = 0
DEADBAND = 0
MAX_OUTPUT = 2000
Harware connections.
Last edit: 06 Jun 2016 10:35 by ommar. Reason: Adding Photo
Time to create page: 0.126 seconds
