Limit error
- ArcEye
- Thank you received: 758
Is there a BOB that isnt expensive that you would recommend for my set up. I was thinking of one from CNC4PC www.cnc4pc.com/Store/osc/product_info.ph...th=33&products_id=45
Looks as good as any and much cheaper than most of their stuff.
It appears to be properly buffered with built in pull ups.
Also has the advantage of numbered screw terminals, so you know exactly what pin you are connecting to
- MAG45
- MAG45
I have made a basic config of how I would suggest you set your mill up
Each positive shared home/index goes to an input and all the neg limits go to one pin in series
I have included the stepconf file so you can open that and play with it if you don't feel confident to edit by hand
Im having a difficult time visualizing this, any chance you can make a quick sketch ?
And would this be a good ParaPort? www.ebay.com/itm/2-printer-Parallel-DB25...&hash=item5d504d10b8
- ArcEye
That should be fine
- MAG45
CNC4PC gets you on shipping !
