Linuxcnc for CNC-STEP HIGH Z 400
- Frustrated Toolpaths
26 May 2019 17:38 #135035
by Frustrated Toolpaths
Replied by Frustrated Toolpaths on topic Linuxcnc for CNC-STEP HIGH Z 400
Hi, did you get your High Z running on Linuxcnc? I will be attempting my own config for one of these soon, it would be great to have a head start.
- pl7i92
- Thank you received: 359
27 May 2019 01:28 #135042
by pl7i92
Replied by pl7i92 on topic Linuxcnc for CNC-STEP HIGH Z 400
he did upload the files in this post
forum.linuxcnc.org/38-general-linuxcnc-q...-z-400?start=0#65183
so there is your start
make shure your version of step-high is compatible as they change from time the oinout and board versio n
27 May 2019 04:48 #135055
Thank you pl7i92.
I had hoped utilisateurflo got theirs running as it's much closer to the machine I will have.
I'll try to post a version that works once I get mine up and running.
- windrad
22 Sep 2019 10:25 - 22 Sep 2019 10:27 #145858
by windrad
Replied by windrad on topic Linuxcnc for CNC-STEP HIGH Z 400
I had the same problem with getting the Zero 3 control working with LinuxCNC. In my case it looks like a problem of the stepconf wizard. The estop and the charg pump for some reason conflict.
In my case it helped to comment out the following:
net estop-out charge-pump.enable iocontrol.0.user-enable-out
and add:
net charge-pump <= charge-pump.out
net estop-ext => charge-pump.enable
in the highz_s400t.hal (see attachment) file after finishing the stepconf wizard. Attention this change is overwritten each time you run the stepconf wizard.
I also attached my latest version of the configurarion. You can use it as a starting point and adapt it to your needs.
and add:
Last edit: 22 Sep 2019 10:27 by windrad.
The following user(s) said Thank You: Frustrated Toolpaths, pagan_dan
03 Oct 2019 14:10 #147013
Thank you,
I ended up with a different machine in the end, a cnc router parts/avid cnc machine.
This produced even more headaches for a linuxcnc controller....got there in the end, it's mostly running as intended, just need to get my estop to talk to linuxcnc via the g540, which shouldn't take too long with a bit of searching
- pl7i92
03 Oct 2019 14:36 #147016
by pl7i92
changing a HIHG end CC to a low cost is not that good behavior if you got the money for it
why did you go for this mashine
there are so many others to be considert on a KIT
like sorotec or dold ....
03 Oct 2019 15:01 #147024
After a lot.......LOT.....of looking and searching various machines for my purpose I decided on the avid machine (with some serious reservations and worries) I have been pleasantly surprised so far by the machine (mine is far from the standard build) and isn't cutting quite yet as I still need to fit the spindle and hook up the vfd through g540 and LinuxCNC.
I had some unusual requirements that took me away from the manufacturer's you mentioned.
- pagan_dan
23 Mar 2023 02:56 #267347
by pagan_dan
Replied by pagan_dan on topic Linuxcnc for CNC-STEP HIGH Z 400
Thanks for the configurations, I have used them to 'almost' get my old s400 working. I am new to LinuxCNC and having trouble translating these older configuration files to the newer format though.
I must be missing something or doing something wrong, as although everything works I'm not get the correct scale for each axis. The manual shows "Steps per Revolution 1/10 Micro-Step : 2000". How does this translate into Motor steps per revolution and driver micro stepping? I have tried many different values but some don't sound good and i don't want to damage anything. The default settings of 200 / 2 'work' but they give a scale of around 66. But these configurations files show scales of 200 / 200 / 333.33333.
From looking at the manuals I just spotted the thread pitch is 6mm for each axis, so I have changed that from the default 5mm. Do i also need to change the motor leadscrew pitch settings?
I have tried editing the .ini file to the scales in the conf files posted here manually after running the stepconf tool, and that got the scale much closer, but still not quite right. Any advice on what I might be missing or things I could try would be much appreciated. I'd rather get this right in the stepconf tool, so I don't need to manually alter settings if possible.
I can upload by configuration files here if that helps.
- Thank you received: 7506
23 Mar 2023 07:19 #267359
Replied by tommylight on topic Linuxcnc for CNC-STEP HIGH Z 400
Is this a G540?
Ball screw pitch can not be 6mm, at least i never saw one, they are 5mm for metric and 5.08 for inch.
2, 4, 8mm for lead screws are pretty much standard.
Are the motors directly coupled to screws?
Example
5mm screw, directly coupled to motor, 200 step motor, G540 divider by 10 (dors not have microstepping), this makes 2000 pulses per revolution divided by 5mm, so you get 400 steps per mm, and this should be the scale in the ini file.
Example
- pagan_dan
23 Mar 2023 10:56 #267368
by pagan_dan
Thanks for replying. As you can tell, I'm new to LinuxCNC, and CNC in general, so apologies in advance.
I'm not using a G540 (although a new controller might be a good idea). The mill is this one :
www.cnc-step.com/high-z-s-400-cnc-router...mm-trapezium-screws/
That is listed with their own Zero3 controller. Mine came with the older Zero2 controller, so that is what I'm using. I found an old server with a parallel port, and installed the recommended version of LinuxCNC on that. I configured it as best I could using the old config files I found in this thread. It does mill, but the scale is about 30% off and the x axis doesn't sound right. It doesn't sound.. 'smooth'
I last used this machine about 15 years ago (I've moved around and it's been in storage) I original used it with their Windows NT/2000 software iirc. They quoted around 800 euros for a USB interface and new win10 software. So it seemed like a good time to jump ship to LinuxCNC
Time to create page: 0.148 seconds
