Linuxcnc for CNC-STEP HIGH Z 400
- pagan_dan
23 Mar 2023 11:40 #267370
by pagan_dan
Replied by pagan_dan on topic Linuxcnc for CNC-STEP HIGH Z 400
On that page I linked to it lists the 'slope' as 6mm, and in the operating manual it lists the following :
Steps/U at 1/10-Step Control : 2000
Thread pitch XY : 6 mm
Thread pitch Z : 6 mm
The stepper motors are Sanyo Denki type 103h7126-0740. They list a step angle of 1.8, so 200 turns. Using your calculation with 6mm, this would give 333.33333 recurring. Which is what is in the config files in this thread for the Z axis, but they have 200 for the Y and Z axis? So I must be missing something somewhere.
The pins took a bit of messing around with to get right, as did the charge pump and the homing directions. But it feels like I'm close now. Everything seems to work OK, it's just this scale issue. Thanks again for your help.
- Thank you received: 7506
23 Mar 2023 19:48 #267387
Replied by tommylight on topic Linuxcnc for CNC-STEP HIGH Z 400
OK, i would first edit the ini file, find lines with step space and step time, make values at least 5000 for those on all axis/joint sections.
See if the motors run smoother.
- pagan_dan
27 Mar 2023 07:28 #267596
by pagan_dan
The step space and step time values were already 5000. I just changed the settings to 600 / 2 for the X/Y axis and to 1000 / 2 for the Z axis to give me the same scales as in the settings files people shared in the is thread. 200 and 333.333333r. I did a test cut of the LinuxCNC logo, and it all gust fine, but it is still 15% to 20% too small.
Is there anything else in the settings, other than this scale value, that can change the scale?
Thanks again.
Thanks again.
27 Mar 2023 09:30 #267605
Set the scale to what your machine needs, not to what internet tells you.
Use a tape measure, move the machine using MDI to 100, then 200, and when you are close to scale, use the maximum travel the machine can do .
- pagan_dan
28 Mar 2023 02:05 #267671
by pagan_dan
Thanks. Good advice. I'm at work at the moment, but I'll do that when I get home. I guess my mill is an even older version than the ones people shared their config files for, and something on it must be slightly different from their mills.
- Phorced
17 Oct 2024 08:46 #312380
by Phorced
Replied by Phorced on topic Linuxcnc for CNC-STEP HIGH Z 400
I know that it is now over a year ago but i am currently setting up exactly the same machine and am not getting any movement just sounds like the steppers are being provided a locking current and that is it would you be willing to provide your configuration file that i can test on my side cause i have tried all the configuration changes mentioned in this forum with no resolve.
- pagan_dan
22 Oct 2024 12:18 #312882
by pagan_dan
Sure, it might take a day or two though as that machine is in bits at the moment and I'm busy at the moment. I haven't used this machine much, IIRC I still had a scaling config issue, but it was otherwise working, and I did a couple of test mills.
Time to create page: 0.263 seconds
