7i92
  • Diederik
  • Diederik's Avatar Topic Author
  • Premium Member
  • Premium Member
19 Jan 2016 16:25 - 19 Jan 2016 16:27 #68764 by Diederik
7i92 was created by Diederik
Hi ,
Does anyone perhaps have Sample configuration files for the 7i92, with 7i77x2?
First time for me to play with this, but I have built alot of 6i25-7i77's, so I'm sure a sample .hal, & .ini file will set me off to success.
(Or even the lines that I need to add to my files, or Documentation where I can find these secrets ;) )
Thanks for the help in advance. :) :) :)
Last edit: 19 Jan 2016 16:27 by Diederik.
19 Jan 2016 17:29 #68769 by PCW
Replied by PCW on topic 7i92
a 7i92 with 7i77 configuration will be almost identical to a configuration with a 5I25 except
for the following:
Card name is changed (so pin/parameter names change)
Driver is different (hm2_eth instead of hm2_pci)
The driver needs the card IP address in the config line
The driver manual page (man hm2_eth) has the setup information
freeby.mesanet.com/7i92step.zip
Is an example step/dir config file set for the 7I92
Note that a big unmentioned elephant in the room is that you need to run
hm2_eth with the uspace version of linuxcnc under Preempt-RT
not RTAI
The following user(s) said Thank You: Diederik
  • Diederik
  • Premium Member
  • Premium Member
19 Jan 2016 20:00 #68777 by Diederik
Replied by Diederik on topic 7i92
Thank you Peter,
I appreciate your help
  • Diederik
  • Premium Member
  • Premium Member
01 Feb 2016 21:07 #69393 by Diederik
Hi Peter,
I have tried your instructions, but no success. Please forgive me, but my knowledge of computers in general is very limited.
Could you please instruct me line by line for the 7i92. Eg. (my lines=)
loadrt hm2_eth config=" num_encoders=6 num_pwmgens=0 num_stepgens=0 sserial_port_0=000xxx"
Etc. What other lines do I require Making it different from 6i25? I changed all 5i25 in Hal file to 7i92, etc.
Please provide me with a sample configuration.
  • Diederik
  • Premium Member
  • Premium Member
01 Feb 2016 21:11 #69394 by Diederik
Please see attached the current test ini and hal files we are trying to test with.
Please assist us and advise where we are going wrong.
File Name: 7i92-7i77-test1.hal
File Size:9 KB
File Name: 7i92-7i77-test1.ini
File Size:3 KB
  • Diederik
  • Premium Member
  • Premium Member
01 Feb 2016 21:12 #69395 by Diederik
Please note that we have completed a mesaflash successfully with the 7i92_7i77x2.bit file.
01 Feb 2016 21:57 #69399 by PCW
freeby.mesanet.com/7i92-7i77.zip
is a known working example file set (using 10.10.10.10 7i92 IP address )
one problem with your sample is you loadrt the driver twice
  • Diederik
  • Premium Member
  • Premium Member
02 Feb 2016 02:30 #69408 by Diederik
Hi Peter,
Thank you,
This seems like the .hal file. What should the .ini commands look like?
I have the following in my .ini file:
[HOSTMOT2]
# **** This is for info only ****
# DRIVER0=hm2_eth
# BOARD0=5i25
  • Diederik
  • Premium Member
  • Premium Member
02 Feb 2016 02:37 - 02 Feb 2016 02:40 #69409 by Diederik
I tried the following in my ini file:
[HOSTMOT2]
DRIVER=hm2_eth
BOARD=7i92
but when trying to start linuxcnc, error is [HOSTMOT2]CONFIG not found
What should I put in CONFIG?
Last edit: 02 Feb 2016 02:40 by Diederik.
  • Diederik
  • Premium Member
  • Premium Member
02 Feb 2016 02:57 #69410 by Diederik
I have now also tried this in my ini file:
[HOSTMOT2]
DRIVER=hm2_7i92
BOARD=7i92
CONFIG=""
But I don't have a clue. I'm hitting in the air, not having proper documentation/reference to work from, I don't know what I'm doing here.
