7i92
04 Jan 2017 18:49 #85247 by Todd Zuercher
Replied by Todd Zuercher on topic 7i92
Sounds like you have a couple of ways you might be able to go. Could you get by with moving the spindle analog out over to the other 7i77? If so you might be able to swap out the one 7i77 for a 7i85. It has 5 smart serial ports and 4 encoder inputs. (You might also need to add another smartserial io card to replace the io you lost from the 7i77 you removed.)
Another way would be to replace your 7i92 with a 7i80DB, giving you 2 more DB25 connectors to add a 7i74 in addition to your 7i77s.
The following user(s) said Thank You: Diederik
  • Diederik
  • Diederik's Avatar Topic Author
  • Premium Member
  • Premium Member
06 Jan 2017 04:51 #85323 by Diederik
Replied by Diederik on topic 7i92
Thanks for all the feedback. For now I decided to cut some Inputs and outputs out, that's not critical, e.g. some pilot lights, and buttons that is not critical to the project right now. So only using the following configuration:
7i92 => 7i77x2 => 7i70, 7i71
But for future, I would like to buy the correct configuration, so, would the following be a good option:
7i80DB, 7i77x2, 7i74x1,7i70x2,7i71x1. And then, The firmware, and possibly sample configuration files for this? And if I understand this correctly, I'll be able to expand further I/O on this?
To make sure I understand this right, Hardware configuration can look like this:
7i80DB => 7i77(1) => 7i70(1)
=> 7i77(2) => 7i71(1)
=> 7i74(1) => 8 x 7i70(2-9)
=> 7i74(2) => 8 x 7i71(2-9)
That will give me 12 Encoder inputs, 12 Analog outputs, 496 Digital inputs, 464 Digital outputs. I know there is no machine that will use this many I/O, but, this is the possibility right?
or Hardware configuration can look like this:
=> 7i74(2) => 8 x 7i70(10-17)
=> 7i74(3) => 8 x 7i71(1-8)
This configuration will give me 6 Encoder inputs, 6 analog outputs, 848 Digital inputs, 400 Digital outputs? I just want to make sure I understand this correctly, and if there is firmware/software on linuxcnc that will support this hardware configuration.
06 Jan 2017 10:59 #85329 by andypugh
Replied by andypugh on topic 7i92
As far as I know the driver should support all that, and it if doesn't then I will fix it.
You can mix-and-match different types of IO cards on the same 7i44 or 7i74.
You could consider:
7i92:
=>7i77 => 7i71
=>7i85 => 7i83, 7i71, 7i70*2
That would have 10 encoder channels, 10 analogue outputs, and more IO than I can be bothered to count right now.
Time to create page: 0.160 seconds
