Barcode scanning to run gcode
03 Apr 2016 11:20 - 03 Apr 2016 11:27 #72614 by beltramidave
Replied by beltramidave on topic Barcode scanning to open gcode
Sorry for the short reply. I thought it was someone here that helped me figure this out before.
In Linuxcnc, the keyboard shortcut to open a file is the lowercase o. If you include o in your gcode filename (otest.ngc)
and then create a barcode from that filename, scanning it will open the file.
I used an free online program to create the barcode. I was using a Honeywell scanner 3800G. There is also a way to run the program too. Will try and find that doc from Honeywell. I decided not to use that as I wanted the operator to make sure they were ready first.
Was really quite simple. Hope this helps.
File Name: barcodegenerator.doc
File Size:1,365 KB
File Name: Scannerset...odes.doc
File Size:38 KB
Last edit: 03 Apr 2016 11:27 by beltramidave.
The following user(s) said Thank You: eFalegname
04 Apr 2016 12:03 #72703 by andypugh
Replied by andypugh on topic Barcode scanning to open gcode
I assume, then, that your barcode scanner acts as a keyboard emulator and sends keystrokes?
I am sure there must be more resilient ways to do it :-)
04 Apr 2016 12:23 #72705 by beltramidave
I am sure there are other and possibly better ways, but this is what I came up with...with my very limited knowledge of Linux and scanners.
  • eFalegname
  • eFalegname's Avatar Topic Author
  • Elite Member
  • Elite Member
04 Apr 2016 17:15 - 04 Apr 2016 17:19 #72728 by eFalegname
Replied by eFalegname on topic Barcode scanning to open gcode
Sorry for not answering before I was looking for a convenient and reliable barcode scanner and found this which is completely linux compatible Inateck BCST-20 WiFi
I was able to add to the axis-remote script the -R (--run) command to start the opened Gcode in Axis (following ArcEye axis-remote for version 2.6 of linuxcnc), then I modified the bash that JT suggested:
if axis-remote -p
then
axis-remote /home/efalegname/linuxcnc/nc_files/matrix_1.ngc
axis-remote -R
fi
When the Barcode scanner arrives I will be able to continue looking for a solution because now I don't get how you can run a python script and a Gcode from a barcode label...I'm a bit confused.
Last edit: 04 Apr 2016 17:19 by eFalegname.
04 Apr 2016 18:06 - 04 Apr 2016 18:55 #72731 by BigJohnT
Replied by BigJohnT on topic Barcode scanning to open gcode
I wrote a little python script this morning that when ran will scan one bar code with a USB webcam then send the parsed results to axis-remote to load the file. I don't have the code in front of me right now or I'd share.
JT
Last edit: 04 Apr 2016 18:55 by BigJohnT.
  • eFalegname
  • Elite Member
  • Elite Member
04 Apr 2016 20:20 #72736 by eFalegname
well I'm almost desperate I want to see the script so I can go to sleep tonight please Big John share it
04 Apr 2016 21:00 - 04 Apr 2016 21:11 #72739 by TurBoss
Replied by TurBoss on topic Barcode scanning to open gcode
Hi
Can you set the scanner to send data via rs232
I was able to do it with a honeywell voyager just by change the wiring (specified in manual)
so you dont have to focus the app to get the data
edit: sry nothing in the manual indicates that this is posible :(
Last edit: 04 Apr 2016 21:11 by TurBoss.
06 Apr 2016 22:54 #72876 by BigJohnT
Sorry got side tracked this morning trying to get someone up and going... I'll dig it up in the am and post it.
JT
  • eFalegname
  • Elite Member
  • Elite Member
07 Apr 2016 07:50 #72896 by eFalegname
:laugh: ok I'm still waiting for you without shutting down the computer.
07 Apr 2016 11:20 #72900 by BigJohnT
Ok, here you go... it's rather short and lacking in the error checking department but functions.
#!/usr/bin/python
import os
import subprocess
from sys import argv
import zbar
# Create a Processor
proc = zbar.Processor()
# Configure the Processor
proc.parse_config('enable')
# Initialize the Processor
# more checking is needed here as it might be video1
device = '/dev/video0'
if len (argv)> 1:
    device = argv [1]
proc.init (device)
# Enable the preview window
proc.visible = True
# Read at least one barcode (or until window closed)
proc.process_one()
# Hide the preview window
proc.visible = False
# Extract results
for symbol in proc.results:
    # Do something useful with results
    print 'decoded', symbol.type, 'symbol', '"% s"'% symbol.data
    file = os.path.expanduser('~') + '/linuxcnc/nc_files/' + symbol.data
print file
if subprocess.call(['axis-remote', '--ping']) == 0:
	print 'Axis is running'
	subprocess.call(['axis-remote', file])
else:
	print 'Axis not found'
Time to create page: 0.604 seconds
